Author: Subject: Bosch 044 Wiring
T66
posted on 30/7/15 at 04:15 PM Reply With Quote
Bosch 044 Wiring
I have a loom from Alan in Spain, The loom has my EWP & Water/Meth pump on their own relays, but as I have just noticed today (but fekkin late) there is no fuel pump wires or relay. The pump I am using is a Bosch 044, so can anyone give me some help on creating a safe new addition to the loom to put 12v at the pump ?
Build is still ticking along, but my absolutely tord shift pattern ensures I feel sh1te permanently, never see my wife and just spend my rest days recovering from the tord pattern driving me to an early grave......
Apart from that all good here, and hope your all ok.
Ivan
jollygreengiant
posted on 30/7/15 at 04:57 PM Reply With Quote
All you need is to take a supply or splice a supply off of the ignition live supply [i.e. the live supply that goes to the coil(s)] to a relay and from the relay to the fuel pump, as you ONLY want the pump running when the engine is running.
HTH's
JGG
T66
posted on 30/7/15 at 05:33 PM Reply With Quote
I thought there was a bit of trickery required, hate electricity I do not understand it. However having looked at diagrams and doubted myself, you have confirmed I want ign1 to switch the relay to the pump. Will an inline fuse be ok seeing as Alan hasnt covered that either \?
luke2152
posted on 30/7/15 at 06:26 PM Reply With Quote
Yeah small fuse (5a) on the relay coil (switch). Big fuse (20a) on the power into the high current side. Nothing wrong with inline fuses. Make sure you use 20a or so wire as the 044 is a big pump.
jeffw
posted on 30/7/15 at 06:31 PM Reply With Quote
I would normal expect the ECU to control the switching of the relay for the HP fuel pump, at least mine does.
T66
posted on 30/7/15 at 07:51 PM Reply With Quote
Just looked , it does ! thanks for the timely reminder
Dusty
posted on 31/7/15 at 10:04 AM Reply With Quote
And that switching is likely to be an earth switch, not live.
