Author: Subject: AL Coolant system tube
Dick Axtell
posted on 18/8/15 at 09:26 AM Reply With Quote
Greetings al LCB-ers. Having gone slightly crazy after searching for anyone who does suitably swaged ally tubes for the Zetec cooling system, am reduced to asking here for supplier info.
Spotted KitSpares product list - "out of stock"! Who else provides such items?
bob
posted on 18/8/15 at 10:02 AM Reply With Quote
The bottom end radiator / water pump pipes were from tiger on my car, they also supply pipes for rail at the top but i decided 32mm and 19mm ali pipe was readilly available and i managed to find a local engineer to turn the ends on a lathe so the jubilee clips take hold.
Dick .... have a look in my photo archive,should be lots of pictures regarding water works.
bob
posted on 18/8/15 at 10:07 AM Reply With Quote
[img] bottom hose connection
[/img]
This was from Tiger, i cut it in half for pipe direction and had the ends turned on a lathe.
[img] Bottom hose 32mm/19mm joints
[/img]
adithorp
posted on 18/8/15 at 10:48 AM Reply With Quote
I think CBS do ally pipe with swaged ends.
http://jpsc.org.uk/forum/
Dick Axtell
posted on 18/8/15 at 10:49 AM Reply With Quote
Bob, thanks for the pics, and your suggestion.
Adithorp, thanks for the tip - CBS my next port of call!
[Edited on 18/8/15 by Dick Axtell]
mark chandler
posted on 18/8/15 at 11:06 AM Reply With Quote
B&Q aerial poles are cheap with bends, then drill a hole an add a nut to some old plier jaws to make a swageing tool.
prawnabie
posted on 18/8/15 at 11:18 AM Reply With Quote
Ash Hoses do to, look around for the discount code before you order though.
Shaun
peter030371
posted on 18/8/15 at 12:15 PM Reply With Quote
Viper Performance and Merlin Motorsport are two suppliers I have used for this before.
Dusty
posted on 18/8/15 at 08:22 PM Reply With Quote
Also used B&Q but copper plumbing 28mm pipe and half a solder joiner makes a good barb for holding a 32mm coolant hose. And you can get a 28x28x15 Tee for that bypass hose join.
loggyboy
posted on 18/8/15 at 08:50 PM Reply With Quote
Aa mentioned, ASH.
http://m.ebay.co.uk/itm/Alloy-hose-joiner-32mm-1-1-4-Silicon-Silicone-Hose-/130463707256?nav=SEARCH
Mistral Motorsport
Dick Axtell
posted on 19/8/15 at 07:46 AM Reply With Quote
Thanks for all the replies. LCB.co.uk - more specialist than Wikipeadia!!
