Author: Subject: Bugger...
AntonUK
posted on 29/8/15 at 11:32 AM Reply With Quote
Bugger...
Just had some time in the garage, one of the jobs was to screw in some eye bolts in to the roof beam to hang various misc things. In the process of winding them in I dropped the screwdriver and it landed... Right through the Ginetta's Radiator... My language was fruitful...
Build Photos Here
cliftyhanger
posted on 29/8/15 at 11:39 AM Reply With Quote
out with the araldite....
Smoking Frog
posted on 29/8/15 at 11:45 AM Reply With Quote
Bad luck. I also used the same language while nailing up plasterboard to the bathroom ceiling. I drop it and the corner smashed a hole in the bottom of the bath.
mike2704
posted on 29/8/15 at 11:57 AM Reply With Quote
bugger
Hi, Just as I was thinking these type of thing only happen to me I read your post how do these inanimate objects cause so much stress and always find the most destructive path
AntonUK
posted on 29/8/15 at 02:04 PM Reply With Quote
I did consider that or trying to solder it, but it would alway play on my mind and it turns out a new one is only 30quid so order has been duly placed.
Picture, 1000 words etc...
[Edited on 29/8/15 by AntonUK]
Build Photos Here
anthony1
Quite a few years ago now , the F27 was in the garage ,alloy all nicely polished , I slid a cupboard door open only for it to fall of its tracks and when trying to catch it.........all in slow motion of course.....it landed corner first right through the middle of the F27 bonnet.......
steve m
posted on 29/8/15 at 02:07 PM Reply With Quote
We all have these problems
mine two months ago, was putting up a new fence in the back garden, did not really need to move the big flowerpot with bush
thing in it, but did, and was blind as could not see over or round the bush, tripped on a fence post lieing on the grass, and fell right arm on to another fence post
Broken arm
steve
joneh
posted on 29/8/15 at 02:18 PM Reply With Quote
I was just using the angle grinder to put some flat spots on my Jeeps shock so the mole grips would grip and ground a big flat into my spring compressor as well.
Hay ho.
posted on 29/8/15 at 04:00 PM Reply With Quote
Funny how this type of problem always seems to happen in slow motion ?
Smoking Frog
posted on 29/8/15 at 05:09 PM Reply With Quote
How true. I think part of your brain has already processed the outcome before it happens.
posted on 29/8/15 at 06:31 PM Reply With Quote
Just been trying to move my new engine and gearbox across the floor.. bent over to heave it and standing up banged me heed off the corner of me V8... OUCH!!!! F F F..... Doh!
sdh2903
posted on 29/8/15 at 06:48 PM Reply With Quote
That's when you know you have too many engines.........
