HAL 1
| posted on 29/8/15 at 03:36 PM |
suspension bushes
Hi
Does anyone know if i can get data regarding suspension bush dimensions, i need some for my kit but only have the sizes, no idea of donor, they were
already fitted when i got it, manufacturer of kit no longer exist.
For info
O/D of bush 25mm ? that's the I/D of tube it goes in, has to be tight fit so slightly larger.
I/D of crush tube 12mm
total length 40mm
I've contacted some manufacturers, waiting for replies.
Thanks in advance
Hal
| posted on 29/8/15 at 05:31 PM |
They normally imperial ain't they??
maccavvy
| posted on 10/9/15 at 09:04 PM |
interested to know about this.. I cant find any to replace mine with .
robin hood 2b with gbs wishbone conversion.
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
steve m
| posted on 10/9/15 at 09:37 PM |
I used Trumph herald poly bushes on my 7, and would say they are about the same dimensions you have quoted
IanSouthLincs
| posted on 19/9/15 at 04:01 PM |
Hi Hal, these dimensions sound very similar to the Cortina ones I'm using, got them from Flo-Flex if that helps
http://www.floflex.co.uk/product_info.php?cPath=23_40_89&products_id=302
[img]http:// [/img]
[img] [/img]
[img] [/img]
