Author: Subject: Fuel Tank and coolant hoses
Lander
posted on 30/8/15 at 05:06 PM Reply With Quote
Hi All,
Looking for a fuel tank for my Avon (carb setup so no return) if anyone has one they are trying to get rid of.
Also looking for full set of coolant hoses and pipes for a Zetec Blacktop if anyone should have some knocking around they don't need.
Thanks in advance,
Ian
furryeggs
posted on 30/8/15 at 07:06 PM Reply With Quote
I also tried sourcing a tank for my avon but found other makes tanks were either to wide, tall, or long, and all the same kind of price as tigers. They no longer supply a steel tank so it's Aluminium only, at £200 inc the correct sender i thought it was worth not having the hassle of modifying the tank or chassis to fit.
Lander
posted on 30/8/15 at 08:48 PM Reply With Quote
Thanks for the info.
Just coolant hoses then please all.
Vmax1974
posted on 31/8/15 at 12:22 AM Reply With Quote
Try speaking to k4kev over on the haynes forum he makes tanks for haynes roadsters am sure he will make one to suit your car if you know the sizes
rm0rgan
posted on 31/8/15 at 11:27 AM Reply With Quote
Hoses, you can get silicon hoses cut to various lengths off eBay along with some alloy tubing with swaged ends/connectors etc. Just ordered some for mine as I needed to install an expansion tank which would be my top tip - Fit an expansion tank!
Sigs are uncool.
