Author: Subject: Clearout
davidimurray
posted on 13/10/15 at 11:16 AM Reply With Quote
Clearout
Having a garage clearout so a few things up for grabs -
Brand New Compressed Air Regulator/Filter/Lubricator - £15 inc postage
Brand New set of ignition leads for a Ford Duratec Engine - SOLD
Wipac rear lens - marked E11, no b or F mark. no bulb holder - £5 inc postage
New Megajolt/Megasquirt/Pinto Ignition Leads - Have a gen 1 coil pack fitting one end and a plain push on cap the other, THe longest off the shelf set you can get (from a KA I think) - ideal if you are mounting the coil pack on the bulkhead as I did. £10 inc postage.
Ford Gen 1 Coil pack complete with connector and wire stubs - £20 inc postage
Type 9 Gearbox rubber mount and bell washer - £12 inc postage
Haynes Roadster Clutch pedal for cable operation - £10 inc postage
Air Hydraulic Pop Riveter - used to fit the floor to my car - a lifesaver unless you look like popeye! Full working order but is a bit dirty as per photos. £25 inc postage
Set of seat runners - only 25mm high. £25 inc postage
[Edited on 13/10/15 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
GavMax
posted on 13/10/15 at 02:55 PM Reply With Quote
hi
I'm interested in the air riveter. What size rivets does it take please?
thanks
Gavin
davidimurray
posted on 13/10/15 at 03:10 PM Reply With Quote
Originally posted by GavMax
hi
thanks
Gavin
Have replied to your PM.
GavMax
posted on 13/10/15 at 03:27 PM Reply With Quote
Thanks Dave
I'll take the air riveter please.
Have re pm'd
Gavin
Lander
posted on 14/10/15 at 09:53 AM Reply With Quote
Whats the width and length (just the runners) of the seat runners ?
Thanks,
Ian
davidimurray
posted on 15/10/15 at 09:34 PM Reply With Quote
Originally posted by Lander
Thanks,
Ian
Each runner is 40mm wide, 360mm long when retracted, 520mm extended.
Dave
davidimurray
posted on 19/10/15 at 08:15 PM Reply With Quote
Bump
Still available with reduced prices -
Brand New Compressed Air Regulator/Filter/Lubricator - £12 inc postage
New Megajolt/Megasquirt/Pinto Ignition Leads - Have a gen 1 coil pack fitting one end and a plain push on cap the other, THe longest off the shelf set you can get (from a KA I think) - ideal if you are mounting the coil pack on the bulkhead as I did. £8 inc postage.
Ford Gen 1 Coil pack complete with connector and wire stubs - £17 inc postage
Haynes Roadster Clutch pedal for cable operation - £8 inc postage
