givemethebighammer
| posted on 11/12/04 at 10:47 PM |
multi connector
I need a multi connector to connect the dashboard loom to the main car loom. Maplins sell both male and female 20 way ATX motherboard connectors (inc
pins) for a PC.
Nothing on the dash is going to be pulling large amps. Is the connector suitable ? Or will it melt ?
Better still they are only £1.29 per side ( obviously 1 male and 1 female required)
thanks
Mark Allanson
| posted on 11/12/04 at 10:58 PM |
Proper automotive ones are cheaper and less fiddly to wire up
givemethebighammer
| posted on 11/12/04 at 11:03 PM |
thanks Mark, I've looked and could only find a 15 way connector (I need 16 way - typical !) at :
http://www.vehicle-wiring-products.co.uk/VWPweb2000/multicon/multicon.html
MNL15 for £5
anywhere else I could try.
The ATX ones are quite large (so shouldn't cause too any issues with wiring ) It was more the current rating I was worried about.
thanks
givemethebighammer
| posted on 11/12/04 at 11:21 PM |
pic
Mark Allanson
| posted on 11/12/04 at 11:53 PM |
As everything on a dash is usually PCB, should be OK
stephen_gusterson
| posted on 12/12/04 at 12:26 AM |
i would guess that each pin is ok for 5 or so amps minimum. so if you are below that you should be fine.....
atb
steve
mangogrooveworkshop
| posted on 12/12/04 at 12:55 AM |
AMP Mate-N-Lok
Thats a mate n` loc type connector they are pretty much universal.
The AMP Mate-N-Lok wire-to-wire and wire-to-board pin and receptacle connector system delivers economical, yet reliable connection for applications
including vending machines, home appliances and computers.
This Tyco product features crimp snap-in contacts.
Locking devices are an integral part of the design, with built-in contact stabilisation and self-alignment mechanisms.
Dual beam contacts on 3mm spacing are available in 2-12 single row and 2-24 double row configurations.
Board mount versions are available in through hole or surface mount versions, and the PCB mount pin header assemblies can be vertical or right angle
styles.
Mate-N-Lok devices are rated at 250V, 5A maximum on 20 AWG wire.
Contact resistance is 20m2, insulation resistance is 1000Mohm, and the mating force is 6.67N per contact.
Recognised by UL, the devices have an operating temperature range of -40 to +105C.
You get a little straw type thing for removing the pins........when you stick em in the wrong
hole!!! wwwrs amp mate-n-loc
[Edited on 12-12-04 by mangogrooveworkshop]
givemethebighammer
| posted on 12/12/04 at 09:50 AM |
thanks 5A should be plenty. It's only connecting gauges and warning lamps.
givemethebighammer
| posted on 14/12/04 at 09:18 PM |
all installed, a bit fiddley but I now have one plug connecting the back of the dash to the main loom.
thanks
Deckman001
| posted on 15/12/04 at 12:01 AM |
Alan at premiere is very good with this sort of stuff
Jason
