zetec
| posted on 12/12/04 at 02:24 PM |
Dash and interior finished.
Finally fitted my new dash and got all the new interior panels in, even new carpet (Big Tart).
Also picked up an imobiliser off Ebay for £2. Thought it would be a piece of crap but when it turned up it looks just the same as £50 jobs. Two
protected circuits, failsafe working, remote key tranducer, unmarked cables. The instructions are a bit basic and unknown make (Sprinter?) and you
have to adapt your key to fit the tranducer, but works just fine. Asked seller why just £2, he says he has bought so many just trying to knock them
out.
mandbsheldon
| posted on 12/12/04 at 02:36 PM |
Trim
That looks fantastic.
Nice job.
| posted on 12/12/04 at 02:42 PM |
Looks fantastic!
Did you do it all yourself? It looks very professional.
Nick
| posted on 12/12/04 at 02:49 PM |
I do like the way you've used 'fill-in' panels between the chassis members instead of one big panel - very distinctive.
Looking very good!
bob
| posted on 12/12/04 at 02:58 PM |
very nice kevin
Your car looked good before but we will have to tidy our cars up up if you come over to our meets again.
zetec
| posted on 12/12/04 at 03:00 PM |
Nicked the idea from the Donkervort pictures I was after a while ago. Very easy to do, just cut the shape out using thin ply or ali and cover,
probably easier than doing the all in one panels I had before. They're covered in perforated leather which I got off Ebay for £20, great big
half hide.
Wadders
| posted on 12/12/04 at 03:35 PM |
Very nice, reminds me of a TVR interior.
half hide.
splitrivet
| posted on 12/12/04 at 04:29 PM |
Really nice Zetec, a credit to you.
Just shows what a bit of lateral thinking can do.
Bob
locoboy
| posted on 12/12/04 at 05:17 PM |
Zetec,
Thats superb,
How have you secured them in between the rails?
Locoboy
scoobyis2cool
| posted on 12/12/04 at 05:37 PM |
That looks awesome, really professional. How are the prop tunnel covers held down? I can't see and screws or anything
Pete
zetec
| posted on 12/12/04 at 06:24 PM |
The side panels are made a tight fit, and each have 3 three inch strips of self adhesive velcro to hold them in. there only light so don't take
much, also easy to pop out if need be.
Tranny tunnel sides have screws on the top returns covered by the two top panels.
Top rear (Blue) panel has a screw fixed into the rear edge which pushes back onto a hole in a chassis tube on the bulkhead area. The front is held
down by the two set screws holding down the front on the handbrake gaiter cover.
The front section rear is held down by a screw hidden by the handbrake gaiter trim. The front fixing screws are under the handbrake gaiter trim.
All put together so I can take it apart when something goes bang!
krlthms
| posted on 12/12/04 at 07:26 PM |
Very nice.
You make it sound easy, but it is quite hard to work with leather. Being non-synthetic, it stretches differently in different places. So to get such
a snug fit in such narrow and awkward spaces is very fine work indeed. Is this your first experience with leather upholstry in a car? If so, double
impressive.
Will you be making a toneau to keep all the nice upholstry protected? Then agin, such a nice job needs flaunting!
Best regards
KT
zetec
| posted on 12/12/04 at 07:52 PM |
I found it no more tricky than vinyl. I did use spray adhesive which is far more forgiving than Evostik, and as with vinyl keep the material in the
house to keep it warm. Also try not to scretch the cover to fit, cut it too big and trim the excess once glued or it will be forever coming
unstuck.
Thanks for all the kind comments, always gives a boost to get on with the next job.
craig1410
| posted on 12/12/04 at 08:38 PM |
That is one of the nicest Seven interiors I have yet seen. Well done indeed!!
I'm using the same seats, harnesses and steering column and if mine turns out half as good as that then I'll be well chuffed!!
Thanks for the inspiration!
Craig.
wilkingj
| posted on 12/12/04 at 09:25 PM |
Zetec...
You have U2U.
Nice interior... WOW!!
Best Regards
Geoff
http://www.v8viento.co.uk
Browser
| posted on 13/12/04 at 12:31 AM |
The clocks you used came from whom please?
Very nice install by the way!
zetec
| posted on 13/12/04 at 08:24 AM |
Clocks from greenguages.com, they have a self design program for options for dial/needle/bezel options. I got the standard small dials and mid size
86mm large dials. Mine are sunk flush with the dash but if you are putting them on the surface you can really only use SVA spec bezel.
pgpsmith
| posted on 24/12/04 at 03:58 AM |
Zete, baby, that is SO SWEET!!!   Oops, sorry, got carried away with internet anonimity... but it IS SWEET! I like the dog-leg joint between the
fr and rr tranny side covers. It adds to the professional look. Any functional reason for the shape? Was it a bear to cover the pointy bit?
Regards,
Pete Byar
Live and don't learn, that's us. - Calvin and Hobbes
zetec
| posted on 24/12/04 at 07:52 AM |
I only did the front side panels that shape as its a real pain getting to anything on the gearbox/prop if you have to take off a full length panel
(seat out etc). Covering not too bad as long as you take your time and the covering material is not rock hard after sitting in a cold garage!
[Edited on 24/12/04 by zetec]
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
907
| posted on 24/12/04 at 09:06 AM |
Hi Zetec,
I can't think of the right words to describe your car interior mate.
I'll settle for "Very Professional", but it's better than that.
How about, "Gobsmacking", that'll do.
Well done.
I'm trying to do a similar thing. If it turns out half as good as yours I'll be well pleased.
Happy Christmas
Paul G
zetec
| posted on 24/12/04 at 09:19 AM |
Thanks mate.
sgraber
| posted on 2/2/05 at 06:23 PM |
I have to add my kudos here too. That is so f-ing beautiful.
The standard to aim for I would say.
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
CairB
| posted on 2/2/05 at 10:32 PM |
That's champion.
Does it mean that you won't go out in the rain though?
Colin
zetec
| posted on 3/2/05 at 08:12 AM |
Being a soft southern tart I don't normally drive in the rain, not too much fun in my eyes. That said I don't think the odd soaking will
do much damage. Next project is a hood or at least a tonneau...Dave's flintstone hood looks a good solution.
Danozeman
| posted on 3/2/05 at 08:39 PM |
That looks soooo nice. welldone mate. Gives me something to aim for..
Dan
