Author: Subject: Black top head on Silver top block ???
JacksAvon
posted on 12/12/15 at 06:15 PM Reply With Quote
Dear collective
I am sure this question must have been asked before but I can not find a thread.
Given that hydraulic lifters are weaker than solids... is it possible to put a black top head on a silver top block ??
Or, can the hydraulic lifters be changed for solid ones ???
Jack
Dick
posted on 12/12/15 at 06:47 PM Reply With Quote
Yes you can fit black top on silvertop block and yes you can fit solid lifters
Paul Turner
posted on 12/12/15 at 07:53 PM Reply With Quote
The blacktop head will bolt on
BUT
because the cam belt pulley arrangement of the 2 engines is entirely different some machining is required to provide mountings for the cam belt tensioning pulley.
As for hydraulic lifters there is nothing wrong with them providing revs are kept below 7500 max. They will go higher but the reliability becomes suspect.
Solids can be fitted to a Silvertop head, some Kent cams use them. Machining is required and again its not cheap.
Please tell us why you appear to be so anti hydraulic follower.
JacksAvon
posted on 13/12/15 at 12:09 AM Reply With Quote
I am not anti hydraulic followers as such.
Depending on cam' and desired rev range.
This is more an attempt to re think a method that was alleged to have created some lap records of the past.
It is said that unbeknownst to others, an outwardly standard 1800 silver top had a very large cam fitted with solid lifters.
This revved past 8000rpm and was generally turned up to 11 on Spinal Tap scale.
All of the above is pure speculation and bares no resemblance to the facts.
AdrianH
posted on 13/12/15 at 10:52 PM Reply With Quote
Apart from lifters is there any other advantage to doing this?
Adrian
Why do I have to make the tools to finish the job? More time then money.
