Author: Subject: Pedal Box
xhx4xzx4
posted on 21/1/16 at 07:39 PM Reply With Quote
Pedal Box
Can anyone help me please?
How easy is it to change a top mounted pedal box (Possibly MK1 MK2 Escort Style) into a floor mounted pedal box?
What sort of leg room gains am i likely to get, alternatively would it be an idea to cut and modify the existing pedals to suit, ideally i could do with gaining aprox 2 inches.
Thank You
joneh
posted on 21/1/16 at 09:21 PM Reply With Quote
You'd need a specific floor mounted pedal set. I can't see you being able to use Escort pedals as the push rods would be under the floor. You'll also probably need to replace the end of the footwell with thicker steel to stop flexing. If this is a fury, the floor on the older ones slopes up and is really thin. It'll flex under braking.
Without looking, you'd need to be handy with a grinder and welder.
FuryRebuild
posted on 22/1/16 at 08:10 AM Reply With Quote
Take a look at my blog here. I did just that work on my fury as well as change the footwell for a curated rather than pinto. Let me know what you think.
www.furyrebuild.co.uk
xhx4xzx4
posted on 22/1/16 at 03:18 PM Reply With Quote
Thank you for the replies, forgot to mention it is actually a Locost roadster, the pedal box atm has a bolt going through the top of the clutch and brake pedal and the accelerator pedal is also hinged at the top.
