Author: Subject: New wheels, will same size all round matter
pistol pete
posted on 11/2/16 at 04:00 PM Reply With Quote
As above.. i am getting mk indy with a busa engine
iuts coming with some lightweight 13's with 185 front and 205 rear both 60 profile..
I am keeping these and getting some good tyres for when i go sprinting
now all i need is aset of wheels and tyres for hacking around when on the road
found a set of 195/50/15 with nankang ns2-r tyres..
am i going to notice this as a problem running same size all round when on the road??
posted on 11/2/16 at 04:16 PM Reply With Quote
It seems accepted that light weight 7 type cars are better with smaller (13" wheels with tyres with a larger sidewall profile. That said, many people run 15" and larger wheels and IMHO you would be OK with the suggested tyre size. One other valuable piece of info is tyre pressure, most seem to get better results at lower pressures of 16-18psi per tyre. On my MK Indy I ran 15" wheels and tyres pressures of approx. 17psi. The car was 2.0 Pinto engined and weighed approx. 600 kgs without me, but with a tank of fuel in the MK supplied fuel tank (weighed on a public weigh bridge).
pistol pete
posted on 11/2/16 at 05:02 PM Reply With Quote
Okay thanks.. yeah like said these are just for occasional road use..
the 13's will be for then i need to "Drive" .. when i need most out of the car..
ns2r's will probably be better same size all round than what staggered normal road tyres will be like..
Ben_Copeland
posted on 11/2/16 at 05:15 PM Reply With Quote
That car was always better on 13s. 195s all round will be fine for the road
Ben
Locost Map on Google Maps
Enter Your Details Here
pistol pete
posted on 11/2/16 at 05:19 PM Reply With Quote
I have been trying to find some 13's.. as know it will be better.. but that is what i am using on the track which is the main focus..
if you know or find any 13's let me know before sat
Ben_Copeland
posted on 11/2/16 at 06:17 PM Reply With Quote
I can't remember what offset Olz used to run. You might want to check when car comes before buying any
Ben
pistol pete
posted on 11/2/16 at 06:23 PM Reply With Quote
ET35
SPYDER
posted on 11/2/16 at 07:04 PM Reply With Quote
The 15s will be about an inch greater on diameter on the front. At the rear they will be near enough the same diameter as your 205s, just slightly narrower. If its for occasional road and they will fit under your front arches ( where they are both wider and taller ) then I wouldn't worry about it.
pistol pete
posted on 12/2/16 at 02:51 PM Reply With Quote
A friend posted on the Westfield owners club, and i have managed to get a set of 13's same as whats on it with some avon zzr's on perfect..
Ben_Copeland
posted on 12/2/16 at 03:21 PM Reply With Quote
Excellent, will you be out this weekend then?
Ben
Sam_68
posted on 12/2/16 at 03:36 PM Reply With Quote
All other things being equal, the large rear tyres ought to be giving you a little more grip at the rear, so if the car has been correctly and accurately set up for them then changing to tyres that are the same size all round will result in an increased tendency to oversteer.
If you do find the change in balance is noticeable, then you could look at dialing it out with changes to other settings.
pistol pete
Well be out picking up on trailer tomorrow and then be out and about Sunday i expect..
Ben_Copeland
posted on 12/2/16 at 03:39 PM Reply With Quote
If you fancy a longish drive come down and say hi !
Ben
pistol pete
posted on 12/2/16 at 03:53 PM Reply With Quote
Thanks mate.. Not sure I will Sunday as seeing deadpool with the missus fr valentines love story an all that...
But we will defo have to meet up.. I am doing a Kent coast tmrun starting in Ashford down coast along Dungeness etc in April with the mr2s. ill run in the busa ad ben in his Westfield if ya wanna come along
Ben_Copeland
posted on 12/2/16 at 03:57 PM Reply With Quote
Yeah, remind me closer the time and as long as its a weekend should be fine
Ben
SteveWallace
posted on 13/2/16 at 12:28 PM Reply With Quote
Just bear in mind that if you change the rolling radius of the wheels that you use to measure your speed, your speedo will be out. Larger radius means that your actual speed will be higher than you measure and therefore you will need to be careful around speed cameras.
pistol pete
posted on 13/2/16 at 12:39 PM Reply With Quote
Thanks but these new ones are for track use only so not too fussed
b14wrc
posted on 16/2/16 at 12:27 PM Reply With Quote
Has anyone done any actual back to back real world testing on the effects of tyre size?
Currently my "locost" is running 225/45/16 front and 255/40/17 rear - apart from the actual weight - my rears are pretty heavy (Pro race 1.2's 9" wide), I ignored all the advice on wheel size ages ago as I don't do things by the book. Plus I’m running an engine which will be running over 300bhp, in the donor car the 16" wheels spun up in 1st, 2nd and 3rd in the dry with standard power....
I just wondered if someone had documented the actual differences, say around a track and obtained track times, or is it more a way the car feels and balance?
I always end up referring back to Lotus as they run 16/17 split on the S2 Elise. I suppose my car is more about aesthetics in some aspects than performance.... It doesn’t really bother me as I’d prefer to try something and see what works/doesn’t.
I note a lot of people run the same size front and rear - i suppose it depends on weight, power drive train etc....
Apart from the speedo error, I’d say you won’t notice much difference in grip between a 195 and a 105. The difference in tyre widths on my car is pretty substantial. Plus the tyre wall hardness on decent tyres also comes into play. I had Yokohama S Drives 195/45/16 on the front wheels initially (only as that’s what they had on) I took them off at my mates garage a few weeks ago (Cheers Kirt!) and they popped off, the Yokohama Advan AD08's were a nightmare to get on, so stiff.
I guess I am just saying there are many factors to look at and some real world data (if available) would be useful.
Rob
20vt powered rear engined locost
b14wrc
posted on 20/2/16 at 12:48 PM Reply With Quote
These are my 1.2's....
Rob
