AlanH
| posted on 14/2/16 at 08:54 PM |
Starting problems
Hello.
I have been having problems in getting my car started. I put it down to a poor battery and just not being familiar with starting an engine with Weber
40's. Somebody suggested a "lazy" starter.
Can anybody explain this or how to check it out?
Cheers.
A
HowardB
| posted on 15/2/16 at 08:34 AM |
Quick check by jumping from another car/battery will tell if it's the battery.
What are the symptoms, slow crank, back fire, flooding?
Really could be a range of things,..
hth
Howard
| posted on 15/2/16 at 12:28 PM |
Some basic checks
First of all you should check the battery voltage -- with the key off after sitting for an hour or two without the engine running it varies with
temperature but you should expect to see expect 12.5v to 12.8v If not charge the battery, let it rest for an hour or so and check the voltage
again.
A quick check is to turn the side lamps on for 5 to 10 minutes to take the surface charge off the batter and then re-check battery voltage if it has
dropped below or 12.4 or more than 0.2v it points towards a bad battery.
You should then try and start the engine and observe the battery voltage while you crank the engine.
The voltage dip when operating the starter should follow a pattern similar to this oscilloscope graph.
Using a digital voltmeter anything above 10v while cranking the engine indicates the battery passes the test, below 9 indicates a bad battery or the
battery terminals need cleaned and tightened.
If the engine still cranks slowly the next check is to put a kown good jump lead between the battery negative and the engine block and try to crank
the engine --- if it cranks faster then you have a bad earth lead connection between the block and the battery negative.
If you car passes all these tests then if you have slow cranking you need to look at the starter or excessive ignition static advance.
AlanH
| posted on 15/2/16 at 07:54 PM |
Slow crank turnover Howard, thought it was flooding but pulled out the plugs and they were dry.
Use a jump start recently to get it going but obviously this needs fixing.
A
