Author: Subject: MOT pass with an MIL light
Hodor
posted on 19/2/16 at 07:29 PM Reply With Quote
Hi
Will my car (regular saab) pass it's MOT despite it having an engine management light on?
Thanks.
liam.mccaffrey
posted on 19/2/16 at 07:43 PM Reply With Quote
i don't think it will pass.
Build Blog
Build Photo Album
tones61
posted on 19/2/16 at 07:46 PM Reply With Quote
Originally posted by Hodor
Hi
Thanks.
yes,pass and advise,
posted on 19/2/16 at 07:54 PM Reply With Quote
Pass and advise , it may however indicate problems that may affect the emmisions
joneh
My old Vectra used to pass and the dash on that looked like a Christmas tree!
Slimy38
posted on 19/2/16 at 07:56 PM Reply With Quote
I hope it's a pass, as my wife's 308 is getting MOT'ed in the morning and the engine light is on!
ian locostzx9rc2
posted on 19/2/16 at 08:11 PM Reply With Quote
Yes it will pass ,as said it may have an emission problem which may not .
smart51
posted on 19/2/16 at 08:38 PM Reply With Quote
I just bought a car with a MIL on and a week old MOT with an advisory due to the MIL.
The fault was both O2 sensor heater circuits. O2 sensors work when they get hot so no MOT problem when warm. I replaced the sensors and reset the MIL. All is now OK.
Hodor
posted on 19/2/16 at 09:24 PM Reply With Quote
Thanks.
I know what the trouble is, there is a secondary air pump which activates for the first 10 secs or so to help reduce emissions during the initial start up then switches off. A one way valve to it packed up allowing exhaust emissions to go through it. Water from combustion condenses in this pump and it in turn effectively drowns. So now the car registers the pump isn't responding and pings the light. The whole system is completely redundant to the point saab deleted it from the car the year after mine. Apparently you can get the proper saab comms gizmo to remove the system from the engine management check, just not gotten round to getting it sorted.
posted on 19/2/16 at 11:18 PM Reply With Quote
A MIL light is the cars way of telling you to FIX the bloody thing.
Some P Codes being set can block other other serious P Codes being triggered.
Hodor
posted on 19/2/16 at 11:32 PM Reply With Quote
Or not, as is my choice. Cost, effort, risk, the usual things you weigh up when something on a 13 year old car go faulty. Maybe I'm less anal than others though who like their dashboard light free, regardless of cost.
joneh
posted on 20/2/16 at 06:09 AM Reply With Quote
My vectra got screen burn on the warning light LCD display.
steve m
posted on 20/2/16 at 08:12 AM Reply With Quote
The light is there, as said as warning, and it could affect the emissions
can u not reset the light off with the OBD port?
if not get the car VERY hot, and give it a good thrash leading up to the MOT, and it will probably be ok
Hodor
posted on 20/2/16 at 08:22 AM Reply With Quote
It'll be fine thanks, the system that is knackered is only used from a cold start. Saab stopped putting them in the cars from 2004 onwards as they were a crap idea to begin with. And at over £140 to fix and a pain in the arse to do I'm going with the "wait and see what I do with the car before deciding how to deal with it"approach.
Yes, can turn it off with the odb but it comes on again after self check at next start up. Although possibly not once car is warm and hence system not needed. ... hmm, might just work, thanks for the idea. Will try resetting it before going in for the MOT. Even though it won't fail for it. Keeps it off the advisory.
[Edited on 20/2/16 by Hodor]
