prawnabie
posted on 21/3/16 at 12:12 PM |
Can an electrician help me please!!
Hi all,
Having ripped all of the electrics out of our garage due to them being fitted from a spur in the kitchen, I have got a sparky coming round to look at
taking a supply out to the garage from the main consumer unit and fitting small CU in the garage.
From this smaller CU I will be running some strip lights from a 6a MCB and a ring for the sockets from the other MCB which is 32amp.
Apaert from the usually power tools I have a 160 amp TIG fitted with a 16amp 3 pin round plug and a 150 Mig fitted with a 13amp normal 3 pin plug - am
I right in thinking that a 32amp ring with the correct rating cable is a no no as the 16amp socket is not fused? If so what rating MCB should I be
looking to get or would you fuse the socket and leave the extra capacity in place?
Thanks in advance for your help - just need to have a bit my info before he comes round!
cliftyhanger
posted on 21/3/16 at 12:34 PM |
No expert, but radial fed my a 16a mcb sounds decent plan to me.
Mr Whippy
posted on 21/3/16 at 12:54 PM |
I have a 175 amp mig on a 13 amp standard plug and never noticed any issues even welding up heavy roll cages, you may be overdoing things a tad unless
Tig's use more current for the same power? then again how often do you weld on full power? I've never used the top setting even welding
6mm plate.
although I did have a arc stick welder on the same kind of setup which melted the plug into the socket, no idea of it's power but it was an
industrial machine and I generally used it as a cheap version of a plasma cutter
posted on 21/3/16 at 01:25 PM |
I'm no electrician, but do run a 150A MIG welder from a standard 13A socket without any issues. That said my CU is in the garage and I have
wired a ring direct from the CU around the garage so it's not loaded elsewhere.
rgrs
posted on 21/3/16 at 04:32 PM |
Dedicated supply for the welder 2.5mm to a 16a socket fed from a 20A mcb type c or d, provided that the earth loop impedance is ok.
But it will be up to your electrician
regards Roger
prawnabie
posted on 21/3/16 at 04:48 PM |
Thanks for the replies!
So I guess one of those "garage" type CU's will be out of the question then as I will need space for 3 MCB's at a minimum.
Cheers guys just wanted to know what to expect!
Shaun
posted on 21/3/16 at 05:15 PM |
Get along to tool station, they do a 9 way CU for less than a tenner.
posted on 21/3/16 at 08:02 PM |
If it were mine, I'd just put both welders onto normal 13a plugs and use 2 neutral pins in each, ie no fuse. It'll save a lot of
faffing.
prawnabie
posted on 21/3/16 at 08:21 PM |
Hi all,
Turns out the TIG can use a 13 amp supply and the 16amp plug was just put on to due to the thickness of the cable!
robinj66
posted on 21/3/16 at 08:23 PM |
I got myself one of these for my garage 3 Way Garage,Shed, Caravan,Workshop Consumer Unit Mains Isolator + 3 x MCB's -
one circuit for lights, one for 13A sockets and one for a 16A supply for my compressor. They will supply c type mcb's if you ask. They also
do CU's with rcd protection.
prawnabie
posted on 21/3/16 at 08:41 PM |
As all my stuff seems to be 13amp now, what happens if the MCB for the ring is 13amp and both welders are being used - is it worth increasing the
capacity with bigger cable and MCB or am I barking up the wrong tree?
Thanks,
Shaun
Mr Whippy
posted on 22/3/16 at 12:57 PM |
Thanks,
Shaun
you can weld with two machines at once? wow
mk7matt
posted on 22/3/16 at 04:27 PM |
If that's for a metal CU then that's a bargain!
With regards to the original post, there's not a lot wrong with feeding a small garage CU from a spur off the kitchen ring.
Garage board would have 6 A for lighting and 16A for sockets.
You could have your 16A socket outlet on the socket radial circuit - just don't use too many things at once as this would trip the MCB.
2.0 Pinto powered Mk Indy.
10 years in the making.
