Author: Subject: Mounting Acewell to Steering Wheel - Wiring?
oliwb
posted on 28/3/16 at 12:54 PM Reply With Quote
Hi folks, not sure if this should really be an "interior" question or not.
I have an Acewell dash that I want to fit on the centre of the steering wheel (Mountney). I'm wondering how would be best to pass the wires? I narrowed it down to three potentials:
1) get some of that multi-cored coiled wire and secure it inside the wheel and on the underside of the column using P-clips (or similar). I'm concerned this will flap around and catch on indicator stalks etc.
2) Drill a hole through the centre of the hub mounting bolt and pass wires down through the steering column. Not really sure what to do with them at the other end of the column as the UJ would sever / abrade them?
3) Buy one of the very expensive QR steering wheel bosses that have electrical contacts.....
Any other suggestions or anyone done something similar?
CosKev3
posted on 28/3/16 at 01:35 PM Reply With Quote
I think the wiring to do a dash on a steering wheel would be too thick?
People use the flexi cord stuff easy enough when it's just a couple of buttons on steering wheel,but a dash would require many more wires.
rodgling
posted on 28/3/16 at 01:47 PM Reply With Quote
I've done option #1 with four-core curly wire for steering wheel buttons, works fine. Might be trickier with more wires, probably doable if you can get some good quality non-bulky wire though.
oliwb
posted on 28/3/16 at 03:41 PM Reply With Quote
I was thinking along the lines of this Multi-Core Cable. Can't actually remember how many cores the Acewell requires. I've got the basic 3150. TBH, I have all of the dials already except a rev counter so even if I just wire up a few of the sensors that would be enough. Is there a trick to where to anchor each end of the cable so as to avoid entaglement with the stalks (ie. do I secure it in front of them on the underside of the column)?
CosKev3
posted on 28/3/16 at 05:07 PM Reply With Quote
I think it will need to be steering wheel side of your stalks,as long as you've got enough to go around your column to full lock you should be ok.
Charlie_Zetec
posted on 28/3/16 at 10:17 PM Reply With Quote
I'm mounting buttons on the steering wheel, and am using that pig-tail multi-core wire. Although I tell you now, I didn't pay Demon Thieves pricing for it!! My approach is going to be to weld a small tab on the underside of the steering column with a hole near the bottom, and use a cable tie or similar part-way along the cable to support it. I'm using an XLR plug on the end and matching dash-mounted socket to enable the wheel and buttons to be easily removed, but there's no real need for this.
oliwb
posted on 29/3/16 at 02:44 PM Reply With Quote
Charlie - where did you get your cable from?
