Author: Subject: Blade airbox
locost7-online.com
posted on 1/4/16 at 05:46 PM Reply With Quote
Blade airbox
I'm going to set my tiger up with the standard airbox, do I need to do any mods? Like turn the airbox the other way round?
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
rgrs
posted on 1/4/16 at 08:02 PM Reply With Quote
Which engine version ?
LBMEFM
posted on 2/4/16 at 05:33 AM Reply With Quote
On my MK Indyblade I at first used ITC foam filters which were OK. I then smartened up the original Honda air box with a coat of paint and once fitted the improvement in performance was noticeable. As you suggest to get it to fit simply turn it 180 degrees, I have also run some tubing from the original intakes up the bonnet scoop to allow it the pick up cool air.
locost7-online.com
posted on 2/4/16 at 07:12 AM Reply With Quote
Looked better through 180 degrees my intention is to run a cold air induction pipe as well
