ian996
posted on 3/4/16 at 09:10 PM |
Bike bodies, vac lines
What do I do with the 4 vac lines that run from each throttle body? Where do they connect to?
mark chandler
posted on 3/4/16 at 10:10 PM |
They go to the MAP sensor
big-vee-twin
posted on 3/4/16 at 10:12 PM |
ITB'S do not use the MAP sensor they use the TPS, you do not need to connect them, they can be blanked off.
http://www.triangleltd.com
kingster996
posted on 3/4/16 at 10:39 PM |
You can use the to balance the throttle bodies- did mine today with a set of motorbike vacuum gauges.
Otherwise leave them blanked off or connected together as they are. As long as they are not open and thus able to suck air in.
I used to be indecisive, but now I'm not so sure
ian996
posted on 3/4/16 at 11:05 PM |
Thanks guys, will block them off. Cheers
mark chandler
posted on 4/4/16 at 05:48 AM |
Yes they do along with TPS, that's what they went to on the bike and where it goes on my megasquirt today, especially important if you want to
boost.
big-vee-twin
posted on 4/4/16 at 01:27 PM |
MS only uses the MAP sensor to take an atmospheric pressure reading at initial start up to work out the start fuel load, then does not use the sensor
after that, it can take the reading without being connected to the ITB's.
r1_pete
posted on 4/4/16 at 02:53 PM |
It depends whether you are running speed density or alpha-n,
Speed density uses the TPS
Alpha-N the MAP combined with IAT to calculate the volume of air.
Speed Density is generally reccomended for ITB's but, if you have a relliable smooth vacuum, good results can be achieved with Alpha-n.
SPYDER
posted on 4/4/16 at 07:40 PM |
You've got SD and Alpha-N the wrong way round.
SD uses the MAP sensor
Alpha-N uses the TPS
Hybrid Alpha-N or ITB mode use both.
Some people using Alpha-N still use the MAP sensor to give a more reliable trigger for acceleration enrichment, particularly if they suffer from a
noisy TPS signal. It is also useful to trigger overrun fuel cutoff.
I am using Alpha_N but I still have the MAP sensor connected to Megasquirt. I find it useful when data logging as MAP gives an accurate indication of
"effective wide open throttle".
I have found another use for the four small vac lines. I have them connected to a small solenoid valve that opens when the radiator fan cuts in. This
counteracts the drop in revs that I used to get.
r1_pete
posted on 4/4/16 at 07:47 PM |
Oops yes you're quite right, thats what you get for playing on LCB during boring voice conferences.....
ian996
posted on 4/4/16 at 10:54 PM |
lol! I'm not the only one then!
