Author: Subject: Wide nose cone
james-w
posted on 25/5/16 at 11:58 AM Reply With Quote
Wide nose cone
I have built the 442E chassis to enable me to shoehorn in an M52 engine from a BMW but I'm struggling to source a nose cone.
Are there any manufacturers that supply a nose to fit a chassis this wide?
Ben_Copeland
posted on 25/5/16 at 12:55 PM Reply With Quote
How wide do you need it? Haynes roadster bodywork should fit over the engine but depends on the chassis dimension.
I have all the bodywork dimensions if you need them
Ben
Locost Map on Google Maps
Enter Your Details Here
Vmax1974
posted on 25/5/16 at 01:07 PM Reply With Quote
I have a nosecone second on eBay if you want one to chop about to make it fit
james-w
posted on 25/5/16 at 03:29 PM Reply With Quote
I don't think height is an issue but the chassis at its widest point at the front is 750mm.
Do you have a link to the eBay item, I've searched but cannot find it?
edit. Found it.
[Edited on 25/5/16 by james-w]
Vmax1974
posted on 25/5/16 at 03:34 PM Reply With Quote
Have a look if it's any good usually me and we can do a deal
Haynes roadster nosecone second
[Edited on 25/5/16 by Vmax1974]
Ben_Copeland
posted on 25/5/16 at 03:44 PM Reply With Quote
https://drive.google.com/open?id=0B7TIJWZFnR1ueHEyVHIzOUFPSzA
https://drive.google.com/open?id=0B7TIJWZFnR1uODlmVGQyYzhHRmM
https://drive.google.com/open?id=0B7TIJWZFnR1ubm96OFN2NndQM0U
That's the equinox Haynes roaster nose one which I'm guessing is pretty much same measurements as vmax's one.
Hopefully you can get the links to work ok
Ben
james-w
posted on 25/5/16 at 03:52 PM Reply With Quote
That's a massive help thanks!
