Author: Subject: Sierra/granada 7.5' 3.64 ratio lsd
stevec33
posted on 18/6/16 at 05:59 AM Reply With Quote
Im selling a 7.5' 3.64 ratio lsd diff, not sure if its granada cosworth or sierra cosworth, came out my westfield running 200hp in good working order, selling due to changing ratio, standard backlash. Looking for £300, collection from Peterborough or arrange your own courier.
mcerd1
posted on 18/6/16 at 07:21 AM Reply With Quote
Measure the output flanges, Granada cossie's use 100mm CV's and sierra cossie's use 108mm ones.....
stevec33
posted on 18/6/16 at 09:00 AM Reply With Quote
Flanges are 108mm accross, thanks
stevec33
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 18/6/16 at 12:49 PM Reply With Quote
Shame that's not a push in shaft - I would have had that !
Is it easy to convert into push in shafts ?
stevec33
posted on 18/6/16 at 02:04 PM Reply With Quote
No idea mate, perhaps someone else may know and comment. Thanks
mcerd1
posted on 18/6/16 at 06:49 PM Reply With Quote
In a word no
if you want to use this one you'll need the rest of the 2wd sierra cossie rear axle bits (or some custom made driveshaft's)
if you don't want to mess about with hybrid shafts or changing the whole lot then your only option for an LSD is an aftermarket one I'm afraid....
[Edited on 18/6/2016 by mcerd1]
stevec33
posted on 21/6/16 at 10:13 AM Reply With Quote
Sold
