russbost
posted on 6/12/16 at 03:15 PM |
Limited slip diffs - Helical
I can buy helical LSD's quite cheaply (comparatively speaking & providing I buy several at a time) but they are only available as standard
for the English & Atlas axles, which I assume are only live axles, not independent.
That in itself wouldn't bother me as I want them to use in a chain drive diff, so would make my own bearing carriers etc., but the English is a
22 spline & the Atlas a 16 spline, are these spline setups the same as any later Ford independent axle diffs, in other words, are there any Ford
driveshafts with c/v's or pot joints that could be used with those diffs or is all the later stuff completely DIFFerent (see what I did there?
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly
recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at
http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
obfripper
posted on 6/12/16 at 04:48 PM |
The early sei westifelds used a english diff/cwp in an alloy housing, i don't know what drive shafts they are paired with.
Dave
minitici
posted on 6/12/16 at 04:56 PM |
The Westfields used their own cases and special output shafts in their early independent rear ends.
bart
posted on 6/12/16 at 11:59 PM |
Ib5
Why not by ib5 type. Takes all fiesta escorts drive shafts ect
BE ALERT > BRITAIN NEEDS LERTS
russbost
posted on 7/12/16 at 08:52 AM |
Simple matter of cost, for instance if I can get a few orders for these, then I could do the English diff for £349.95, & the Atlas unit for
£384.95, in both cases that's about £40 less than Rally Design have these at, they are the Professional Traction Blackline units, I believe the
Quaiffe IB5 is over £600, so that's quite a difference!
But for the diffs to be any use to me I need to have an inboard joint that would be a fit for the spline
minibull
posted on 7/12/16 at 03:06 PM |
Lotus Elan used english diff in lotus housing. So splined output shafts are available. Shame they will cost a lot more than any discount on your diff,
don't know of any others.
Mick
Ugg10
posted on 7/12/16 at 03:43 PM |
Found this - may be the same as the ones you are looking at but for a landrover, think they had splined drive shafts as well -
http://www.ashcroft-transmissions.co.uk/limited-slip-differentials/ashcroft-atb.html
You might also find some inspiration on here as well - http://chaindrivediff.co.uk/about/home/shop/
[Edited on 7/12/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
russbost
posted on 8/12/16 at 11:43 AM |
Don't actually need any inspiration, we already have our own chain drive diff using the Toyota donor diff, but I was looking for a cheap way of
doing a LSD & a supplier coincidentally offered me these diffs.
Just need a way of using one of those diffs with ordinary driveshafts rather than solid halfshafts :s
If anyone is interested in the diffs for English or Atlas setups I could see if we can get a group buy together, if anyone's interested then u2u
or email me at russbost at googlemail dot com
English LSD
[img]
  English LSD
[/img]
Atlas LSD
  Atlas lsd
To be able to do the prices I have listed above I need to get at least 5 orders for whichever diff (if I can get half a dozen combined that would also
do it)
snapper
posted on 8/12/16 at 06:57 PM |
The cheapest option is to strip out a Sierra LSD as all the LSD bits are in the housing the crown wheel bolts too.
Yes I know it's a viscous diff but it's the cheapest option and will take Sierra shafts
SVA passed first time... Trousers in the wash to remove stains
russbost
posted on 8/12/16 at 07:02 PM |
I would have thought decent second hand Sierra LSD's would be a bit like hen's teeth by now!
Ugg10
posted on 14/12/16 at 09:48 PM |
Look what just popped up on eBay
Ford English LSD 22-Spline Differential Helical Traction System, Blackline Gears
