Author: Subject: Dremel bit for engraving chassis number?
mikeb
posted on 1/6/17 at 09:39 AM Reply With Quote
I have a standard dremel, what bit do people recommend for engraving the chassis number?
Charlie C
posted on 1/6/17 at 10:41 AM Reply With Quote
Hi
I used the Dremel Engraver which worked ok and the chassis number was ok for the IVA test.
Charlie
pekwah1
posted on 1/6/17 at 10:57 AM Reply With Quote
I also used the engraver as Charlie has posted. Got good results from this and a plastic stencil
mikeb
posted on 1/6/17 at 11:09 AM Reply With Quote
Would the bit work in a normal dremel?
pekwah1
posted on 1/6/17 at 11:13 AM Reply With Quote
No, the engraver reciprocates rather than rotating like a normal dremel, plus i don't think it's removable
Christof
posted on 4/6/17 at 07:38 PM Reply With Quote
i bought the reciprocator and didnt get on with it, noisy and hard work with limited end result.
bought a pack of fine tips off amazon for a normal dremel (well my draper copy) and found it much more efficient...
end result shown on my 1999 striker build in jpsc forum
ps i found lacquer etc didnt react well with my hammerite finish so have just used vaseline until after iva
pps, i printed off the vin and taped on then engraved through the paper, worked well
[Edited on 4/6/17 by Christof]
Slinky
posted on 5/6/17 at 09:38 AM Reply With Quote
chassis number.
If you don't fancy doing it yourself, try Bespoke Vehicle Developments.
They offer a full VIN service. VIN tags and Chassis numbers. Cheap too!
Quite a few of the members have used them with excellent comments.
They have a pneumatic marking machine. Their website is www.595s.co.uk (Under VIN SERVICES).
Slinky.
