Author: Subject: 220mm Friction Plate
tomduffield13
posted on 18/7/17 at 07:32 PM Reply With Quote
Last part for my Pinto to Duratec with Type 9....
I'm using an ST150 flywheel and Pressure Plate, looking for the matching Friction Plate, 220mm, 23 teeth 1 inch Type 9 centre.
Has anybody got one lying around before I purchase a new one?
Thanks.
peter030371
posted on 19/7/17 at 10:24 AM Reply With Quote
Will your old Pinto plate not fit or is it worn out?
tomduffield13
posted on 19/7/17 at 07:43 PM Reply With Quote
The Pinto one is 190mm which is considerably smaller... I assumed I would need the correct size...
peter030371
posted on 20/7/17 at 08:59 AM Reply With Quote
Must be two 'standard' size Pinto plates then as mine is 215mm and is working fine after 50 miles on a Duratec to type 9 install
tomduffield13
posted on 20/7/17 at 09:07 AM Reply With Quote
I think the older Pinto were 190mm, with the later being 215mm. If i can't find a 220mm, i'll go with the Pinto.
I think the Mk1 Mondeo 1.8 Petrol were 220mm with the correct 23 teeth for the type 9....
Can anyone confirm?
snapper
posted on 25/2/18 at 01:24 PM Reply With Quote
Pinto 1.6 engine has a smaller clutch which is probably the 190mm you measured
2.0L is 216 mm with a clutch cover bolt PCD of 245mm
Fiesta ST150 has a clutch friction plate 220mm and a cover with PCD of 240 mm
I’ve just bought a Mondeo/S Max clutch cover and plate with PCD of 250mm which is what my lightweight Duratec flywheel is drilled for, I haven’t received it yet so don’t have dimensions of clutch plate
I eat to survive
I drink to forget
snapper
posted on 9/3/18 at 10:16 AM Reply With Quote
Which does not fit my flywheel because the friction plate centre is to wide and the clutch cover is for a raised lip DMF
Aaahrg
I eat to survive
I drink to forget
big_wasa
posted on 9/3/18 at 11:40 AM Reply With Quote
Yes the mk1 1.8 mondeo has a 220mm clutch with the 1" 23 spline centre as it used the mtx75.
The mk2 still has the 220mm clutch but has a smaller centre as it was fitted to the lower duty ib5 box.
I could probably find a part number on the box in the shed of it would help.
