Author: Subject: Polishing exhaust manifold!!!!!!!!!
Bigboystoys
posted on 20/10/17 at 09:19 AM Reply With Quote
Morning all,
What are people using to polish their exhaust manifolds these days and what process?
Many thanks
Sam
posted on 20/10/17 at 09:30 AM Reply With Quote
I didn't polish mine, but wrapped it...
dunk3
posted on 20/10/17 at 09:51 AM Reply With Quote
I used autosol, used a drill with a buffer attached and a dremel for the smaller awkward bits
kenton
posted on 20/10/17 at 04:40 PM Reply With Quote
Not very locost but had mine ceramic coated by Zircotec. Dont wrap it, over time they will rust under the wrap
Bigboystoys
posted on 20/10/17 at 05:13 PM Reply With Quote
Thanks for reply everyone, mine are currently polished just getting a bit discoloured and wanted to give them a good going over.
Thanks Sam
mark chandler
posted on 20/10/17 at 10:19 PM Reply With Quote
Tile acid for me, the stuff that dissolves concrete! Chemical attack and save the hardship of rubbing.
Bigboystoys
posted on 21/10/17 at 07:38 AM Reply With Quote
Any particular one Mark? Just looked and a lot of them say don't use on metal but I'm guessing you ignore that?
Many thanks
Sam
Simon
posted on 21/10/17 at 11:17 AM Reply With Quote
Or look up metal polishing in your area and let them do it on proper polishing equipment. No idea on cost but deffo a lot less aggro.
mark chandler
posted on 21/10/17 at 08:23 PM Reply With Quote
Many thanks
Sam
Do not use on mild steel as it will rust like crazy afterwards as it etches the metal, , stainless it's fine just cheap stuff from B&Q As its phosphoric acid
http://www.bssa.org.uk/topics.php?article=77
Alternatively cillit bang, alkaline.
[Edited on 21/10/17 by mark chandler]
snapper
posted on 22/10/17 at 11:49 AM Reply With Quote
Don’t do the acid cleaning in a confined space, even with a mask it’s dangerous
I eat to survive
I drink to forget
907
posted on 23/10/17 at 07:11 AM Reply With Quote
The proper stuff for acid cleaning is called "Avesta BlueOne." It's a gel so tends not to splash.
Can't see the point myself as the more you clean it the quicker a manifold discolours.
The trick the Classic Bike Brigade use for shows is to run the engine very rich so the chrome downpipes stay shiny, or,
take the bike on a trailer and push it to the stand. I know of one bloke who doesn't put any oil in.
Another point is that quality materials polish up better. A 316L stainless manifold will lend itself to acid cleaning & polishing
but at the other end of the scale 409 Chrome Steel doesn't. You pays your money and make your choice as they say.
One more thing. If you breath the fumes in a confined space you can feel a burning sensation in your air passages, but on the
bright side it does remove nasal hair.
Paul G
Angel Acevedo
posted on 25/10/17 at 01:28 AM Reply With Quote
Fine emery cloth followed by Stainless Steel passivation paste.
Maybe the passivation paste may work by itself as it is used to remove welding discoloration.
Boothy
posted on 28/10/17 at 05:57 PM Reply With Quote
bought polishing wheel and compound set of ebay about 12 quid bought filthy manifolds up on motorbike like brand new
Boothy
posted on 2/11/17 at 07:38 PM Reply With Quote
Also to keep it clean, scotchbright cloth and raid the cupboard for the cillit bang !! i kid you not works ace
Bigboystoys
posted on 24/11/17 at 09:02 PM Reply With Quote
Thank you all for the replies
