Author: Subject: help no sound on my computer
jacko
posted on 9/11/17 at 09:09 PM Reply With Quote
Hi all
the sound has stopped working
we have a videologic sound box running the speakers and its stopped working can i just plug the speakers into the tower ?
as you will guess i know nothing about computers
jacko
jossey
posted on 9/11/17 at 09:40 PM Reply With Quote
Check your speakers work OK first by pluggin your phone in.
Check you PC isn't muted goto bottom. Right of screen and see the speaker and check if it's on or muted.
Play something on your PC and then right click on the speaker at the bottom right and see if you see the green bar move up and down with sound.
That's a good starting place.
Good luck
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
gremlin1234
posted on 9/11/17 at 09:52 PM Reply With Quote
presuming its a windows 10 or similar pc,
turn it off and on again. (proper powered off, not just restart.)
else, usually there is a speaker 'icon' on the task bar, which you can 'click' and it shows volume, but also at the top shows where the sound is routed to. change this to the device it should be, not muted, and at 80%vol.
posted on 10/11/17 at 08:49 AM Reply With Quote
Good luck
Sounds like the place to start - making sure you're PC's sound isn't muted.
jacko
posted on 10/11/17 at 04:57 PM Reply With Quote
looks like the videologik sound box has packed in no power light is on and when i striped it it smells burnt inside
O bugger any ideas welcome
posted on 10/11/17 at 05:37 PM Reply With Quote
Worth having a proper look to see what's gone. Might just be some burst capacitors or a single item which has failed...
jacko
posted on 10/11/17 at 06:17 PM Reply With Quote
Yes it looks like i will have to have it looked at
Im not into electrics but the brother in law is
