Regan_M
posted on 7/2/18 at 07:25 PM |
12" wide rear arches??
Hi Guys,
I anyone aware of any kit car builders / manufacturers etc who make and sell 12" / 305mm wide rear arches?
Any help is appreciated.
Thanks,
Matt
Edwardo
posted on 7/2/18 at 08:11 PM |
The GBS Zero rear arches I bought off Ebay are 12.5" wide.
Tony
Edwardo
posted on 7/2/18 at 08:33 PM |
Just measured them - they are actually 315mm wide (12.4" inches.
Regan_M
posted on 7/2/18 at 09:12 PM |
Cheers Tony, thats a tad too wide for what I am after but will bare it in mind
voucht
posted on 7/2/18 at 11:35 PM |
Equinox ones are 290mm wide (11,42''.
Too small ?
555
Regan_M
posted on 13/2/18 at 12:54 PM |
Yes 290mm is a little too narrow for what I am after 305mm - 310mm would be perfect, I was even considering the GBS arches until I saw the price at
£177 each.
CosKev3
posted on 13/2/18 at 06:06 PM |
Have you looked on kit car direct?
Pretty sure MK do a standard or a wide,but not sure on actual width
Regan_M
posted on 13/2/18 at 07:27 PM |
Yes they do a 290mm and extra wide 345mm I believe, thanks though 👍🏻
CosKev3
posted on 14/2/18 at 09:15 AM |
Ah right.
What's your reasoning for needing the odd size?
Mash
posted on 8/6/18 at 09:15 PM |
Actually, I'm in the same boat
the normal ones are too narrow, and the extra wide ones are too wide, suspect it's an offset thing. Might be exacerbated by my rears being
8" wide.
I actually bought some from the bay of evil which were meant to be MK Indy wide arches, but the radius is all wrong didn't realise unntil I
got them home....
Regan_M
posted on 9/6/18 at 07:47 AM |
8" wide.
got them home....
I didn’t manage to find some at the required width in the end so I bought some off a eBay shop that were 300mm wise then trimmed the inner lip of the
arch to give myself some extra clearance however my rear wheels are 7j wide / Et35 offset with a 195 50 15 tyre and my rear tub is about 110cm wide
making the total car width outside rear arch to the other outside rear arch 1710mm.
I’m also running a Granada drive train with the 7.5” diff, 105mm driveshafts etc if that helps
Matt
