Author: Subject: Welding an engine block lug Back on
will121
posted on 25/5/18 at 06:29 AM Reply With Quote
Is it possible to mig weld a gearbox mounting lug back on?
CosKev3
posted on 25/5/18 at 07:07 AM Reply With Quote
You don't say if it's steel or alloy?
Steel will be fine, as long as you've got quite a powerful MIG
JAG
posted on 25/5/18 at 10:21 AM Reply With Quote
An Engine block won't be Steel.
It will be Cast Iron which is very different.
You may make it stick together with a MIG welder but it will not be strong.
The problem happens because Iron castings have minute pockets of Graphite in the metal matrix and these bits of Graphite will contaminate the weld and it will not be very strong.
Cast Iron can be welded but you need an expert or specialist.
Have a read of this page; Lincoln Electric
Justin
posted on 25/5/18 at 10:35 AM Reply With Quote
I believe that cast iron can be bronze-brazed, but I don't know about its strength. Mind you, Caterham chassis used to be (may still be) bronze brazed.
The older I get, the better I was...
will121
posted on 25/5/18 at 10:50 AM Reply With Quote
its a zetec silvertop engine block, so cast iron. its been running with the lug broken off (but still in place as a snug fit) for some time. As im taking the engine out tomorrow was looking to try weld it back on if possible
jacko
posted on 25/5/18 at 11:05 AM Reply With Quote
http://www.mig-welding.co.uk/cast-iron.htm
Have a read
madteg
posted on 25/5/18 at 02:07 PM Reply With Quote
Can stick weld back on with cast iron rods, but you will need to get a grinder in because it wont be neat
prawnabie
posted on 25/5/18 at 02:21 PM Reply With Quote
I had the clutch cable lug snap on my type 9 and welded it back on by heating both parts up with the blow torch and using the mig. I then gently heated them less and less until they were lukewarm.
No sure if that is a proven method but it lasted a few years until the gearbox broke internally!
rash12
posted on 25/5/18 at 05:59 PM Reply With Quote
get some cast rods and stickweld it on then tidy up afterwards with grinder
trextr7monkey
posted on 25/5/18 at 08:01 PM Reply With Quote
I had a pair of steering arms on a car that had been lifted and someone had cut the ends of forming a fork rather than an eye which MOT tester pointed out wasn’t the safest way of arranging things
A local blacksmith fixed them using the pre heating technique, excellent result and not expensive
Good luck
madteg
posted on 27/5/18 at 10:19 PM Reply With Quote
What gearbox is it. If you can get it to me i will do it for you.
will121
posted on 28/5/18 at 08:18 PM Reply With Quote
Thanks for the offer, the mount was part of the zetec cast iron block not the gearbox, I've managed to weld/poop it back on. Will see if it sticks together
posted on 29/5/18 at 04:41 PM Reply With Quote
I have had good success with welding cast iron exhaust manifolds with stainless MIG wire, but the only way it ever works for me is to get the casting as hot as possible prior to welding and let it cool very slowly. If you don't you can hear the cracks forming in the iron as it cools and the resulting join is very weak.
Then again that's fairly easy to do with an exhaust manifold, but quite a problem for an engine block.
