Author: Subject: Calling Wiring experts for general advice on technique and set up
mcg
posted on 19/9/18 at 03:16 AM Reply With Quote
Hi - I am considering re-wiring my f27 clubman over the winter as am having reliability issues with some of it. When building the car I did all of the wiring myself using random coloured wires. Everything is hanging inside the scuttle which is a nightmare to access to diagnose any issues. Wires come through into engine bay into a box that contains the fuse box. Fuse box is so tightly packed that again it is a nightmare to work with.
Everything ‘has’ been working correctly in the past but I am thinking of rebuilding a loom that does it all ‘proper’ and neatly, enabling sensible access for maintenance. So...here are my questions:
1. How to people manage the access to the back of the dashboard?
2. Is the bottom of your scuttle enclosed so you don’t have oddwires hanging down a bit into the footwell?
3. How do you neatly organise your fuse box so wiring and management of the system is good.
4. Wire colour system?
5. Wire connection types for electric components? (On pre trackday inspection I could see that certain connections like the reverse switch on the gearbox have come loose)
6. How do I correctly set up the switched live connections when there are multiple feeds coming off of it? As I built the wiring set up one circuit at a time, I found myself cutting into the ignition live feed (after fuse box) and soldering in take offs at multiple locations along the wire to feed the various electronic components. Seems a bit messy but the best I could think of.
7. Organising relays in a good way.
If anyone has an idiots guide rough diagram to overall approach and set up that would be great to see!
Look forward to hearing.
Many thanks
Matt
jossey
posted on 19/9/18 at 04:43 AM Reply With Quote
Hope this helps
I had my wiring loom cable tidied to the back of the dash with enough loose to allow the dash to drop down flat. Around 6 inch slack.
Enclosed at passenger side and cable clips siliconed to underneath of scuttle to allow wiring to stay away from drivers space. And keeps wires away from. Steering column a friend of mine got his entangled in his steering and caused an accident. I would have preferred to adhesive them to the back of the dash away from the drivers area but my dash was carbon and nothing stuck to it for long. Not even tiger seal.
I bought a fuse box and attached to a shelf that dropped in the passenger side so I could change a fuse easier. Next time I'd move to under bonnet like on westfields.
Copied the westfield wiring colours to help with issues.
New wiring I used black for earth and bought a lot of striped colours I could use and noted them in a book.
The waterproof ones off ebay. Like these but not good for thick wiring.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.de%2Fulk%2Fitm%2F392120375929
Sorry no help on this. I think my solution was a bodge. Maybe. I used one of these inside an electrical box to distribute live.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F163084108306
Sorry can't help.
David Johnson
Nickp
posted on 19/9/18 at 06:30 AM Reply With Quote
I used a pre made loom that matched my column stalks from here - http://www.premierwiring.co.uk/
I'd recommend doing it that way but it depends how much time you have on your hands?
I still had a fair bit of custom wiring to do as I used a BMW engine and all its loom / electrics.
All my wiring lays in an alloy cable tray behind the dash.
zetec
posted on 19/9/18 at 07:28 AM Reply With Quote
While I could have made my own loom I too found it easier to buy a decent premade loom for the main circuits, and then just added my own loom for the engine bay. The main advantage is that you get a colour coded loom to start off with rather than source all the individual colours yourself. But it will depend if you are using stalk switches or individual ones. From my experience poor wiring is one thing that can make a good car a pain in the arse, and if done right in the first place should almost be "fit and forget". Too do a neat job it is probably worth try to take the dash out and then you can make sure each connection is 100% and the loom can be fixed in place.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 19/9/18 at 08:34 AM Reply With Quote
For my MK Indy I used a 2.0 Pinto engine and Vicky Green wiring loom. I made the dashboard myself and underneath (see photo below) I fitted an ally panel with relays and fuses etc. so I sould reach them, but so that no wires were hnging down. My dashboard was also removable in case I needed to get behind it for mods/repairs (never did though).
Not in the photo, but I also used permanent marker pen to write the function of each relay and fuse on the ally next to it to make it easier to identify. IIRC the relay to the far right is the Ford hazzard flasher relay from the donor Sierra.
[Edited on 19/9/18 by nick205]
mcg
posted on 19/9/18 at 10:59 AM Reply With Quote
thats great - thanks everyone. Plenty to think about and apply to my new set up.
Theshed
posted on 19/9/18 at 12:02 PM Reply With Quote
Why get hung up on different colours? Neither aircraft nor motorsport looms bother with this. Just as good to use bands of coloured heat shrink at each end. I would also suggest using heat shrink to bunch the wires together and stop them vibrating.
Get the right crimp tools for your connectors and use solder as a last resort (it corrodes and is bad with vibration).
If you want to add lightness then use light gauge wires for sensors and the like.
posted on 19/9/18 at 12:30 PM Reply With Quote
Ditto on getting the right crimping tools for the crimps. Cheap tools often appear to work, but very often often make poor joints!
big-vee-twin
posted on 19/9/18 at 01:44 PM Reply With Quote
My dash is wired into a loom fastened to the back of the dash, it terminates into a multi pin plug and this allows me to remove the dash from the car very easily, nothing hangs down underneath.
[img] dashboard wiring
dashboard wiring
[/img]
[Edited on 19/9/18 by big-vee-twin]
http://www.triangleltd.com
trextr7monkey
posted on 19/9/18 at 06:17 PM Reply With Quote
If of any interest have the Vicki green loom diagram to give away on another section of the forumhttps://www.google.com/imgres?imgurl=https%3A%2F%2Fimages.esellerpro.com%2F2466%2FI%2F752%2F92%2F44688.jpg&imgrefurl=https%3A%2F%2Fwww.megafa ncydress.co.uk%2Fcurves-nun-costume-44688.html&docid=NJviOiZRPiXP1M&tbnid=GrTyfptJtavHKM%3A&vet=12ahUKEwjX7J38ycbdAhXMposKHUFDCUw4yAEQMyg0 MDR6BAgBEEM..i&w=900&h=1200&client=safari&bih=529&biw=320&q=nun&ved=2ahUKEwjX7J38ycbdAhXMposKHUFDCUw4yAEQMyg0MDR6BAgBEEM&a mp;iact=mrc&uact=8
snowy2
posted on 23/9/18 at 03:36 PM Reply With Quote
there is a "How to" here on this site..... many folks have used it to rewire their cars with little or no issues....
sometimes you are the pigeon, most of the time the statue.
