Author: Subject: Quick rack or alternative?
mcg
posted on 19/9/18 at 03:21 AM Reply With Quote
Noticed on track day that we needed to do a lot of hand over hand steering and so figured a quick rack could be useful. Does it make an appreciable difference for track driving or is there a better alternative?
Nickp
posted on 19/9/18 at 06:13 AM Reply With Quote
If it's an escort rack then yes it's your best / easiest option to swap it for a quick rack. They're cheaply and readily available in various ratios, 2.9, 2.4 and 2.2 IIRC. If it's something else then you'l need to do a bit more research.
AdamR20
posted on 19/9/18 at 06:56 AM Reply With Quote
Yes. Other option is shorter / cut down steering arms, depending on which uprights you have.
Bluemoon
posted on 19/9/18 at 08:45 AM Reply With Quote
Just make sure it is quick, i.e. mm/turn is higher. Some "quick racks" are not, they are just shorter!!
Make sure the length of the rack is the same as the existing one, to ensure you don't get bump steer. Wise to investigate and understand bump steer before investing in a new rack..
Dan
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
mcg
posted on 19/9/18 at 10:57 AM Reply With Quote
excellent - thanks all. I think it is the escort one, so had hoped for a like for like replacement. However when I search for them, some things are coming up that look like replacing only the rack and pinion elements like this:
2.2 Quick Rack
Am i wrong about that?
owelly
posted on 19/9/18 at 11:34 AM Reply With Quote
http://www.rallydesign.co.uk/product_info.php?products_id=7310
http://www.ppcmag.co.uk
Bluemoon
posted on 19/9/18 at 01:16 PM Reply With Quote
2.2 Quick Rack
Measure the rack length, yours may already be shorted (I would expect this to reduce bump steer, but this depends on the suspension design). You might have to get a machine shop to shorten the rack in the linky...
[Edited on 19/9/18 by Bluemoon]
mcg
posted on 19/9/18 at 01:36 PM Reply With Quote
will do - thanks alot
