Printable Version | Send to Friend
Subscribe | Add to Favourites
Author: Subject: Front bone brackets
Avoneer
posted on 19/1/05 at 10:29 PM Reply With Quote
Front bone brackets
Right guys,
I have 8 brackets and 4 bones.
What's the best way to get everything aligned correctly and which bracket shall I start with first.
Pat..
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   Avoneer 's Aim
Northy
posted on 19/1/05 at 10:34 PM Reply With Quote
Got any bush?
Graham
Mix
posted on 20/1/05 at 09:10 AM Reply With Quote
I made an 'H' shaped assy with holes driled in the legs to accept threaded rods the same distance apart as the upper and lower mounts. The brackets were secured to the threaded rod at the required separation with nuts. I then tacked the lower brackets in position, rotated the 'H' frame around the lower pivot to bring the upper bracket in contact with the chassis and tacked them.
I've seen examples of another jig to ensure the lower two pairs of brackets remain parallel but I didn't find it too difficult to achieve this by accurately clamping the chassis to the baseboard and marking out on that.
Mick
James
posted on 20/1/05 at 12:45 PM Reply With Quote
Pat,
These any good?
I would use the lower, rear bracket as the datum point and work from there.
Hope that helps,
James
View User's Profile E-Mail User View All Posts By User U2U Member   James 's Aim
ned
posted on 20/1/05 at 12:48 PM Reply With Quote
I did the same as james, but with some old bits of ply/mdf i had floating around. also remember to mark the centre lines of the cross members of the jig and align these with the centreline of the chassis so the brackets are correctly positioned in all planes. Plenty of g-clamps come in handy, start with the bottom wishbone, bottom bone rear mount is the easiest to position first imho as it sits flat on the lower chassis rails....
oh, and measure it lots of time before tacking it up
Ned.
[Edited on 20/1/05 by ned]
beware, I've got yellow skin
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
Mix
posted on 20/1/05 at 03:13 PM Reply With Quote
Oh and I almost forgot!!!
I fitted FU 1&2 at the same time as the brackets.
Mick
James
posted on 20/1/05 at 03:22 PM Reply With Quote
Mick
Nah, it's much more fun just to drop lucky like I did and have them in exactly the right place!
James
Mix
posted on 20/1/05 at 03:34 PM Reply With Quote
Looks like theres's a bit of a gap on that right hand upper rear.
Mick
Mix
posted on 20/1/05 at 03:46 PM Reply With Quote
Ned
The book is wrong !!
Please check the position of your top bones before going much further
Mick
Avoneer
posted on 20/1/05 at 04:36 PM Reply With Quote
Cheers guys.
That's everything I need to know.
And I agree, Ned has definately got his front top bones in the wrong place.
Pat...
ned
posted on 20/1/05 at 04:45 PM Reply With Quote
Ahem - pic was 'work in progress' and i must say they have progressed a little closer to the front of the car now!! i've also replaced my 'gaffa tape special' shocks.
Ned.
James
posted on 20/1/05 at 05:31 PM Reply With Quote
Mick
Hey, I'm not that lucky!
James
Connectivity donated by NetrinoUK
All content © 2001-6 LocostBuilders. Reproduction prohibited
