Author: Subject: LSD 3.92
sdv builder
posted on 23/1/05 at 05:30 PM Reply With Quote
LSD 3.92
Does anyone have a 3.92 LSD and drive shafts off a sierra they want to sell?
Darren
Avoneer
posted on 23/1/05 at 07:05 PM Reply With Quote
Might have a 3.62, shafts and brakes, all fully re-conned and painted for sale soon...but won't be cheap.
Seen them go for £200 plus on the 'bay.
Pat...
richijenkin
posted on 23/1/05 at 08:04 PM Reply With Quote
got some drive shafts (off a non-lsd - will they fit a lsd?) for £30 if u want
Avoneer
posted on 23/1/05 at 08:18 PM Reply With Quote
IIRC all bolt on drive shafts are the same.
Pat...
sdv builder
posted on 24/1/05 at 01:43 PM Reply With Quote
I've already got push fit drive shafts, just need a 3.92 LSD to go with them, or if someones got a LSD with lobros then that would be good as well.
DarrenW
posted on 24/1/05 at 03:15 PM Reply With Quote
wilkingj has one for sale. See for sale section.
ned
posted on 24/1/05 at 03:24 PM Reply With Quote
don't think ford made a 3.92 lsd for push fit driveshafts and the only lsd 3.92's were on late dohc 4x4's, you need to get an lsd dif and put the internals on the 3.92cwp you already have.. someone has had this done for about £80 iirc
Ned.
[Edited on 24/1/05 by ned]
beware, I've got yellow skin
sdv builder
posted on 25/1/05 at 03:39 PM Reply With Quote
Still looking for 3.92 LSD, what ever drive shafts.
Darren
andrew.carwithen
posted on 25/1/05 at 08:06 PM Reply With Quote
Keep looking in your local 'Free-Ads' as this is where I managed to pick mine up from!
(3.62 LSD c/w driveshafts, hubs and calipers for the princely sum of £50!)
Andy.
Mr G
posted on 29/1/05 at 10:28 PM Reply With Quote
You can use push in driveshafts on a bolt on lsd diff.
Take the back plate off and remove the circlips that hold the bolt on input flanges on. You can then take the flanges off to reveal splines the normal push in shafts will go into.
HTH
G
sdv builder
posted on 31/1/05 at 08:13 AM Reply With Quote
Thanks Mr G, that means I can stick with the shafts I've got, excellent.
Still looking for LSD 3.92 though.
[Edited on 31/1/05 by sdv builder]
sdv builder
posted on 15/2/05 at 08:55 AM Reply With Quote
Just taken the flanges off the diff and the push in shafts do not fit, they're too small. Lobros it will be then.
