Author: Subject: Tps help
Shooter63
posted on 2/11/19 at 08:59 AM Reply With Quote
Tps help
As you guys are the font of all knowledge, I thought I would ask on here, I'm in the early stages of doing a Bmw k1100 16v head conversion on a classic mini engine, the throttle bodies have the tps bolted on the end as per normal but the one fitted as std is known not to be that good to work with. The problem is that instead of the D shape it has a flat bar to turn the tps, so the question is, do you guys know of any other tps that use a flat bar to turn it.
Shooter
CosKev3
posted on 2/11/19 at 10:08 AM Reply With Quote
Ford do,not sure which models exactly but deffo the V6 mondeos.
Yamaha do too if you require a small one,the early R1s I've had did atleast.
Some of the flat bars are slightly diff sizes though,so you might need to file it down slightly to make one fit.
40inches
posted on 2/11/19 at 12:06 PM Reply With Quote
As Kev says the Ford V6 uses a flat connection, but they used 2 types, one clockwise and one anticlockwise.
perksy
posted on 2/11/19 at 05:04 PM Reply With Quote
*If* you do need to file the tab down to get it to fit make sure it's a really good fit with no 'slop' or you'll have issues
CosKev3
posted on 2/11/19 at 05:54 PM Reply With Quote
It's the width of the tab,not the thickness going by the one I've modified that's different.
So filing it down cant alter how it works.
big_wasa
posted on 2/11/19 at 08:03 PM Reply With Quote
The Tps is spring loaded so there should be no slop.
r1_pete
posted on 3/11/19 at 11:06 AM Reply With Quote
The Rover 200 / 400 series use a slotted tps, you’ll find a throttle body complete with tps for a tenner, I bought several whilst building the twin body inlet on the rv8.
Shooter63
posted on 3/11/19 at 02:15 PM Reply With Quote
Thanks for all the ideas and tips, much appreciated
Shooter
