Author: Subject: Finished my rocket stove
posted on 31/5/20 at 02:32 PM Reply With Quote
Finished my rocket stove yesterday and had a test burn
posted on 31/5/20 at 02:44 PM Reply With Quote
And does it sound like a rocket? (that's why they're called 'rocket stoves' )
And will you put a pan stand on the top?
[Edited on 31/5/20 by David Jenkins]
The older I get, the better I was...
adithorp
posted on 31/5/20 at 03:17 PM Reply With Quote
Come on! It's a kit car forum and therefore "finished" doesn't mean "finished" in the traditional sense
http://jpsc.org.uk/forum/
posted on 31/5/20 at 03:19 PM Reply With Quote
Of course! Silly of me!
(my car still isn't 'finished', even after 12 years on the road)
posted on 31/5/20 at 03:30 PM Reply With Quote
Still to add pan supports at the top of the chimney section. Then will heat water and cook bacon.
And yes once burning well there was a roar noise.
snapper
posted on 31/5/20 at 03:49 PM Reply With Quote
I donít know what it is but it has welding and fire so Iím in
I eat to survive
I drink to forget
posted on 31/5/20 at 03:55 PM Reply With Quote
Search "rocket stove" on YouTube.
I've not welded for some time so it's not brilliant, but hangs together.
Fire - yes - hot, very
adithorp
posted on 31/5/20 at 04:02 PM Reply With Quote
I wonder if having 4 small inlets (one from each side of the chimney) that doubled as legs would work instead of one large one?
posted on 31/5/20 at 04:52 PM Reply With Quote
I think it's a case of "it ain't broke, so why fix it?" - I've seen all sorts of designs for rocket stoves made out of square steel tube, and they all look similar to each other.
The biggest bonus with them is that they'll happily burn twigs and small sticks to keep the fire going.
theconrodkid
posted on 31/5/20 at 04:58 PM Reply With Quote
oh dear, what have you started now...off to the man cave int morning
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
gremlin1234
posted on 31/5/20 at 05:01 PM Reply With Quote
a burning desire
posted on 31/5/20 at 05:59 PM Reply With Quote
That may work, but the hollow legs on mine are balance bars made from steel I had already. The main body design is taken from the many before have done it. It works well so no complaints from me.
bi22le
posted on 31/5/20 at 09:43 PM Reply With Quote
Thanks for sharing this.
I started watching a how to make videos and one has provided a great solution for me.
I have a patio by my house and young kids so I don't want a permanent chimnea or BBQ. There were some guides on stacking bricks to make rocket stoves and loose brick fire pits. Perfect for those long dinner evenings when we are finally allowed guests round.
Please read my ring story:
posted on 1/6/20 at 06:44 AM Reply With Quote
That was my aim as well, space to use, time to kill, tools sat idle and kids who like watching fire
posted on 10/6/20 at 03:37 PM Reply With Quote
Another "finishing touch" to add. A member on here has kindly sorted me some exhaust heat wrap. I shall wrap the vertical section to make sure as much heat as possible goes up and isn't lost.
I'm waiting for photos of what you've built now guys
Irony
posted on 11/6/20 at 08:51 AM Reply With Quote
I wonder if the top tube could be extended to 10ft long and then used to heat a garage or workshop?
Mr Whippy
posted on 11/6/20 at 12:11 PM Reply With Quote
What tends to happen when you extend a flue to much is the gasses cool down and then all the stuff in the smoke, resin, soot, tar etc come out on the insides of the flue and then are a fire risk (although a fire in metal pipe...well bonus heating!), but if the smoke does get too cold then it won't go up there or will be difficult to light or will blow back.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
posted on 11/6/20 at 02:41 PM Reply With Quote
The vertical section height on mine was set following what others seemed to have done (mainly waithing YouTube fabrication videos). I believe the principle was to achieve maximum heat at the top of the vertical (chimney) section where the pan/kettle will sit. It's designed for cooking on after all so you're trying to capture the most heat you can. This is where my idea of wrapping the vertical section in exhaust heat wrap comes from to try and maximise the heat at the top and minimise heat loss out the sides.
Still got to finish the pan stand for the top of it as well yet!
