Author: Subject: Painting stainless
Mr Whippy
posted on 4/8/20 at 01:17 PM Reply With Quote
Painting stainless
Rather than the shiny stainless of the 2b I was thinking of painting the shell with just the added benefit that it will not rust later... I did consider a wrap but as the car is covered in rivets that would look very crap. Is there a special primer specifically for stainless I should use and do I have to sand the oxide layer off first? can't say I've ever painted stainless before tbh but I've seen painted Deloreans
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
coyoteboy
posted on 4/8/20 at 01:50 PM Reply With Quote
Just an etch primer, no?
Report your local potholes, it actually works!
posted on 4/8/20 at 02:23 PM Reply With Quote
Only tried painting stainless a couple of times and only used the same primer and paint I'd use for mild steel. It didn't stay on their for long. I resolved myself to the fact it was stainless and shouldn't rust anyway (I know some stainless grades do). TBH it was more effort trying to clean it off without wrecking the stainless beneath.
r1_pete
posted on 4/8/20 at 02:26 PM Reply With Quote
Thorough scuff with 240 grit DA, followed by an acid etch, or epoxy primer.
snapper
posted on 4/8/20 at 06:28 PM Reply With Quote
That’s the way to do it... said Mr Punch
Joking aside that is indeed the way to do it, you need to scuff up the shiny surface to let the etch primer do its job then follow normal paint prep protocol
I eat to survive
I drink to forget
Mr Whippy
posted on 4/8/20 at 07:47 PM Reply With Quote
Ok makes sense, thanks
