Author: Subject: Sizing an alternator belt
posted on 19/10/22 at 11:46 AM Reply With Quote
Afternoon all.
Got the car back from Glasgow eventually - home at 5am! Saved 600 over the cost of recovery at least....
Anyway, the problem was the alternator belt vanishing. How do you pick a size, given that the donor would have had power steering too? Just measure and guess?
It's a pinto, only has to go round the drive and the alternator.
Tempted to just guestimate and order a few!
Fatgadget
posted on 19/10/22 at 12:28 PM Reply With Quote
Use a bit of string!...To work out length and therefore diameter.Voila.
obfripper
posted on 19/10/22 at 12:48 PM Reply With Quote
10x863mm is for a pinto cortina, should be the same for yours.
Dave
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 21/10/22 at 04:41 PM Reply With Quote
Here is how I did it :
https://vouchtroadster.blogspot.com/2013/06/modif-du-suppor t-dalternateur-custom.html
Beginning of the post does not concern the belt, so scroll down until you find date "15/04/2013" in yellow.
Hope that will help
555
posted on 21/10/22 at 07:15 PM Reply With Quote
I used a tape measure and ended up 2 inches short! Sorted now though.
