Miks15
posted on 28/1/23 at 06:57 PM |
Lots of parts for sale
Evening all,
I have a bunch of parts for sale from a project which hasn't been touched in a good while. Finally decided its time to get rid of the parts I
have. Most of the parts I have are new and only been dry fitted but never run.
I won't put loads of pics up, but if anyone is interested message me and I can send more details and photos through.
2x Baby cub bucket seats with headrests. Unused. 1 runner. The other can be solid mounted. £50
2x Front cycle wings. Fiberglass. Need trimming and painting. £40
2x Sabelt 4 point seatbelts. Blue. Pads and bolts included. Date of manufacture 2003. £50.
VW Polo rad with pull fan fitted. Both new. A few marks on the rad fins. £30
Escort steering rack. £50
Escort steering rack solid mounts £10
Escort track rod ends x2. £10
2x Photon twin headlights. £140
Acewell dash with clip on surround with 8 warning lamps. £100
2x LED slimline stop/Tail & indicator light £40
LED slimline Rear fog light £30
LED slimline reverse light £30
12v socket and shroud £5
Horn. £5
Savage aluminium switches. Engine start, fog, head lights, side lights, hazard. £50 for all
Steering wheel. Measures around 290mm on the outer edges. Hub fitted to suit e36 bmw column. £30
Silicone hoses. Blue. 32mm 90deg elbow. 38-32mm reducing 90deg elbow, 38mm 90deg elbow. £5 each
Flexible silicone hose. Blue. 38mm. 70cm long. £15
Flexible wire reinforced silicone hose. Blue. 38mm. 28cm long. £5
Ally straight hose joiner. 32mm & 38mm. £3 each.
Flexible fuel filler hose. 2inch/51mm. 50cm long. £10.
3 chamber Brake/clutch reservoir. Low level switch in cap. £15
Gsxr600 carbs. £50
Alternator. Mitsubishi brand. Can't remember exact details but was bought under recommendation for kit car usage. £20.
All parts located in Grantham, Lincolnshire. Or can be moved to Warwick if you're not in a rush. Will calculate postage costs if interested.
Thanks.
keljon
posted on 31/1/23 at 09:29 AM |
will pm you as after a few parts
quote: Originally posted by Miks15
Evening all,
Horn. £5
Gsxr600 carbs. £50
Thanks.
Striker Returns
posted on 31/1/23 at 01:28 PM |
hi. Are the escort rack mounts still available. Do you have a picture of the steering wheel.
snapper
posted on 31/1/23 at 02:36 PM |
I have pm’d you about seats and may also be interested in lights and hoses
I eat to survive
I drink to forget
Deckman001
posted on 1/2/23 at 03:01 PM |
Hi ya, Am interested in the Alternator, can you send me any info you have regarding it's size, power rating and fixing details?
Jason
U2U sent
[Edited on 2/2/23 by Deckman001]
Miks15
posted on 2/2/23 at 06:31 PM |
U2U's /emails sent
Miks15
posted on 13/2/23 at 08:04 PM |
Updated list of available parts.
Horn. £5
Gsxr600 carbs. £50
Thanks.
