907
| posted on 3/2/05 at 09:10 PM |
English Wheel
With a little bit of prompting from a mate,
I'm contemplating having a bash at making one of these.
Anyone ever used one ?
Aluminium wheel arches would be sooo nice.
With a bit of practice maybe even a nosecone ?
Paul G
mangogrooveworkshop
posted on 3/2/05 at 09:49 PM |
So dam expensive!
http://www.eastwoodco.com/jump.jsp?itemType=CATEGORY&itemID=829
Mark Allanson
| posted on 3/2/05 at 10:11 PM |
For anyone with a decent welder and a lathe, it could be a locost proposition?
mark_UK
| posted on 3/2/05 at 10:13 PM |
Might get some ideas here: http://allshops.org/cgi-bin/community/cforums.cgi?forumid=109061855423990
and this one:
http://www.roddingroundtable.com/tech/articles/12ewheel.html
[Edited on 3/2/05 by mark_UK]
stevebubs
| posted on 3/2/05 at 10:23 PM |
Frost Used Section
Browser
| posted on 3/2/05 at 10:32 PM |
Had a look at that one and it looks great! I'll definitely HAVE to try and get the bits together for one and have a go. Always wanted one but
could never justify the expense, but I think I can stretch to a couple of bearings and can probably scrounge the frame metal from offcuts from local
fabricators.
[Edited on 3/2/05 by Browser]
mark_UK
| posted on 3/2/05 at 11:05 PM |
quote: Originally posted by Browser
Had a look at that one and it looks great! I'll definitely HAVE to try and get the bits together for one and have a go........
At thetime I was looking about 6 months ago one guy had a site up showing you everything drawings sizes the lot.Unfortunately someone pointed out he
could make some money from it,needless to say the web site disappeared Doesnt look too hard to "wing it" tho
Rob Lane
| posted on 3/2/05 at 11:08 PM |
Eddy White was selling a bench mounted version on ebay not long ago for something around £150.
The larger ones fetch a lot of money.
Martin at MK made himself a freestanding one quite cheaply I believe.
timsta
| posted on 3/2/05 at 11:23 PM |
'ere you go: http://www.metalcrafttools.com/engwheel.html
You shouldn't need the plans, it all look simple enough.
Or, step by step: http://www.roddingroundtable.com/tech/articles/12ewheel.html
[Edited on 3/2/05 by timsta]
CairB
| posted on 3/2/05 at 11:25 PM |
I'm sure that some of the FEA designers amongst us could present a minimum metal, optimised solution made from left over 1" RHS, a bit of
hydraulic tubing, used wheel bearings, and a pair of wheels for the diy toolers to fabricate.
Then we can all hum those old favourites whilst we fabricate such as:
We'll meet again..
4 wheels on my waggon..(sorry that's american)
Colin
907
| posted on 4/2/05 at 12:37 AM |
Another one is:-
This shows how to make one, including the rollers, a "Ford axle bearing" and a "pillow block bearing".
I'd estimate £70 for the whole thing.
Paul G
Soul-tez
| posted on 4/2/05 at 03:39 AM |
There is a ton of metalshaping info here http://www.metalmeet.com/forum/index.php
Rorty
| posted on 4/2/05 at 05:49 AM |
I cant let this topic go by without posting this link.
Cheers, Rorty.
timf
| posted on 4/2/05 at 08:25 AM |
for those making the full sized ones.
and needing anvils etc
look here for a us vendor who exports and for a resonable price
| posted on 4/2/05 at 08:42 AM |
You could also look here
The Tin Man
The frame doesn't look too hard to a man with your skills - but the hardened rolls are expensive!.
| posted on 4/2/05 at 08:28 PM |
Good replies chaps, but still want to find someone who has used one.
Anyone know where you can buy "casenite"? ( case hardening powder )
Paul G
| posted on 4/2/05 at 09:12 PM |
Paul,
It's spelled with a 'K' - Kasenite or Kasenit - I know a few model engineering suppliers but they tend to sell small quantities
only. Blackgates Engineering is one - a Google will find them.
Otherwise it comes in big tins - £82 + VAT for 5kg is one I found!
gazza285
| posted on 4/2/05 at 10:04 PM |
You could take the anvils to your local engine refurb spot and ask then to nitride/tuffride them.
Rorty
| posted on 5/2/05 at 12:10 AM |
quote: Originally posted by David Jenkins
Paul,
In the good old days before proprietry case-hardening compounds, blacksmiths and toolmakers used various recipes to impart a higher carbon layer on
steel. Ground hooves and horn were favoured by my local blacksmith; he just plunged machine parts into a bucket of the powder. A friend in NI was a
turner and fitter for Goodyear and he preferred his secret mixture that contained sugar! It smelled like candyfloss when he used it. Basically,
anything that's friable and high in carbon will do the trick.
I made a really smart pair of large dividers and case-hardened them in the hoof and horn mix. I still have them to this day and they are perfect; no
perceivable wear or surface damage.
Cheers, Rorty.
907
| posted on 5/2/05 at 07:43 AM |
I like the idea of the sugar Rorty.
I assume that it would catch fire if a red hot lump of steel was dipped in it.
At a lower temp it would turn to toffee.
Ummm, maybe I'll try that.
Paul G
NS Dev
| posted on 5/2/05 at 11:28 AM |
907, if you have an oxy-acetylene torch and plenty of gas, just flame harden!
Get a rich flame going and play it over the part for a good while, then up the oxygen and blast it until dull red and quench.
907
| posted on 5/2/05 at 05:05 PM |
It makes me think of my college days.
" The Products of the Oxyacetylene Flame "
O, the good old days.
Paul G
907
| posted on 26/10/05 at 07:38 PM |
The day I start making the bodywork is looming, so I thought I'd better crack on with the "wheel".
It's cost me £48 so far, so a waste of money..... or a bargain?
I'll probably knacker loads of ally sheet,
then go and buy some fibreglass.
Paul G
| posted on 26/10/05 at 09:29 PM |
Um... isn't the bottom wheel supposed to adjustable up and down? The real e-wheels have a big wheel at the bottom to adjust the roller
spacing.
Or is that bit hidden somewhere?
Rorty
| posted on 26/10/05 at 09:47 PM |
Yes, the anvil has to be adjustable. Here's my set-up:
Cheers, Rorty.
