Author: Subject: Can anyone identify this plug?
John Bonnett
posted on 12/3/23 at 02:43 PM Reply With Quote
I'd like to source the mating half of this plug and would be grateful if anyone could identify it and where to source it.
The plug is from the aircon compressor on a MK1 petrol Focus.
Thank you
John
obfripper
posted on 12/3/23 at 04:05 PM Reply With Quote
I can't help with the plug itself as it's not present on the catalog plug diagrams, but it is part of the a/c sub loom, which is finis number:1041416.
However i draw a blank in actually finding this loom as a current part, it might be worth changing to a more commonly available plug.
It doesn't look like any third party connector i can think of, so is likely to be unique to ford, iirc it's different to the connector on a ka, the same on a mk1 focus, a/c wasn't common on any of these age vehicles, which makes even finding a second hand one difficult.
Dave
John Bonnett
posted on 12/3/23 at 05:42 PM Reply With Quote
Dave
Dave thank you so much for taking the trouble to check for me. I'm just being lazy in wanting to retain the original plug because it will be only be the work of half an hour or so to fit a new one.
Kind regards
John
loggyboy
posted on 13/3/23 at 09:55 AM Reply With Quote
https://www.alibaba.com/product-detail/2-Pin-Ford-Round-Female-Sealed_1600224411454.html
Out of stock sadly
https://evolutioncarparts.co.uk/products/sl-106759-sl106759
[Edited on 13-3-23 by loggyboy]
Mistral Motorsport
McLannahan
posted on 13/3/23 at 10:08 AM Reply With Quote
Might be in stock on his ebay page -
https://www.ebay.co.uk/itm/304426939820?hash=item46e14275ac:g:t1YAAOSwuBhiSsyx&amdata=enc%3AAQAHAAABAFHUAc%2FkVAGsyPp1r6G71onfVwJBA7S6v0HCGkj7FiL4 yJtbCL%2Ft9Iro8loHtqj2Ka1iefVj%2FfEgYaHJwtRtWRaAYuxiFQnI%2BHupiS93G3HMySCdsc%2BcFMd%2FdqwB%2BRyhhOt%2BNT%2BvzUIIkVrxUV3h9ntQLSqCVBIrTBMqo%2FqPdWQazXPE 8TDhAp3xgislujR3K4VYutJyRAgJrOQaWvwnqz3kpZr2pR%2FjW4Sj6rkmIFEJOqJCyHOJOX6LTOi5K8fAydD7CT8W%2F6VMvm%2B4FOzzrEim%2FXADFOQRuuAXXYZ6Wu2%2FlkSBDWsK7VDeK8jt oSBPcVd928aEb2c0qScwWwTz%2FcI%3D%7Ctkp%3ABk9SR9CrhafbYQ
John Bonnett
posted on 13/3/23 at 01:12 PM Reply With Quote
Absolutely fantastic, thank you both of you. Order's in and what a result.
big_wasa
posted on 13/3/23 at 08:30 PM Reply With Quote
John Bonnett
posted on 13/3/23 at 10:15 PM Reply With Quote
Originally posted by big_wasa
Thank you for the diagram
Does it matter which wire goes to earth because on my after market compressor, both wires are black?
Thank you,
John
big_wasa
posted on 14/3/23 at 08:13 AM Reply With Quote
Its just a coil so should not be polarity sensitive.
John Bonnett
posted on 14/3/23 at 09:08 AM Reply With Quote
Yes that was what I was thinking so thank you for the confirmation.
It's all getting quite exciting now and I'm sure everyone on this site can relate to one's feelings on the build up to the first start up. Wiring the aircon system isn't pivotal to firing the engine but being close to the alternator, the cable to the compressor can be wrapped together with a number of others including the alternator, water and temperature senders.
