MikeR
posted on 18/2/24 at 11:54 PM |
electricity "base" load?
Just going to bed and I noticed the electricity meter.
What is your base load? The amount you use when nothing it's actively being used?
When I turned off the computer it was nearly 400w, watching it now it's dropped to 250 to 300w. 250 send high, 400 ridiculous butt I don't
know if that's just me being a grumpy old man.
I've no idea what is eating the power. I guess it's a combination of fridge, sky boxes and cctv. I turned off the outside lights and that
saved 15w (then I put them back on).
SteveWalker
posted on 19/2/24 at 12:45 AM |
It seems surprisingly high. Ours is usually around 400W, but we have a home server running 24/7, 3 satellite boxes permanently powered up, two
networked printers in standby and various other tech.
coyoteboy
posted on 19/2/24 at 08:12 AM |
Items running:
Dehumidifier
Central heating boiler (60W when active)
3x Network switches
1x Mini PC
2x CCTV Camera
1x modem
1x Router
Baseload
Mr Whippy
posted on 19/2/24 at 10:02 AM |
Why is everything running on standby, are we at war?!
Can things just not be off?
peter030371
posted on 19/2/24 at 10:49 AM |
Our background load is 230W. This includes 2 fridges, a freezer, 4 TVs, a network printer, 1 router, 2 WiFi hot spots, 1 FTTP connection box, 1
outside CCTV camera, cordless phone (x2) and a load of USB charges of which one or two are always being used by someone or other. I don't think
230W is too high considering everything and we do tend to buy better specified (lower power) appliances such as the fridges and freezers.
coyoteboy
posted on 19/2/24 at 10:59 AM |
Given modern switch mode suppliers, standby is fractions of a watt.
By far the biggest contributors to my normal usage are the fridge and the boiler. All my standby devices summed up account for about 5 quid a year,
I'll cope for the convenience .
peter030371
posted on 19/2/24 at 11:02 AM |
Yes and no, ask any TV repair man when most TV or set top boxes go wrong and it has always been when switching on from cold. I could go around and
switch off at the wall our 4 TVs every night and accept that every year or two one will break when switched on from cold and cost how much to replace
(£500-£1k depending on which one it is)?
The standby current is less than 1W per TV. Financially it makes no sense to switch them off. Environmentally it is possibly a different answer but
that depends on if the reduction in carbon footprint by using less electricity outweighs the increased carbon footprint by replacing a TV every few
years as repairs are often impossible.
coyoteboy
posted on 19/2/24 at 11:06 AM |
I think this is a bit of a red herring to be fair, modern TVs usually fail (as far as I see from online forums) due to the caps in the main power
supply failing, or a part downstream getting a spike due to the cap not functioning properly. This occurs when the TV is powered on from cold
primarily because thats when the biggest transitions occur. But the thing that was the root cause is the capacitor, which likely died due to heat and
time-on. If you keep the system on, it doesn't "fail" because the cap isn't as critical in an always-on situation, but that
doesn't mean it's not already failed. It's like saying failure is caused by braking for junctions, when in reality someone cut your
brake pipes at the last stop, you just hadn't needed them until now. But I must admit, I'm not an expert in analogue electronics.
[Edited on 19/2/2024 by coyoteboy]
Mr Whippy
posted on 19/2/24 at 01:12 PM |
Well I grew up at the time of "What's your bedtime routine...?" so I go round and switch everything off and I certainly don't have
enough faith in Chinese manufacturing quality to leave something waiting on standby just to go bang and burn my house down.
coyoteboy
posted on 19/2/24 at 01:30 PM |
You do you, as the kids say, but based on my data set the highest risk by about 4 orders of magnitude is kids with lighters.
posted on 19/2/24 at 02:27 PM |
My meter says 63w right now. There will be more cycling on and off - mainly the boiling tap and the electric floor in the bathroom.
Mr Whippy
posted on 19/2/24 at 02:44 PM |
My kids of 8 & 10 light our big wood burning stove, I figured it was safer to learn to use matches properly than possibly experiment by
themselves. The large 3 story house just a couple down from us was burnt to the ground about 5 years ago due to kids playing with matches. Have to say
it was very dramatic with hot embers flying all over the place, and then the roof collapsed and it was like a volcano!
coyoteboy
posted on 19/2/24 at 03:50 PM |
My friend burned his house down despite us being freely allowed access to regular bonfires and being scouts, he just liked playing with fire lol
SteveWalker
posted on 19/2/24 at 05:54 PM |
Our home server needs to be available 24/7 - it deals with collecting and distributing our emails to our PCs and phones, including for our son who
lives away at university and often is using email or storing files on our server at silly times of the night. It also needs to be available
constantly, as our satellite boxes use it for storage and powering it down will lose the connection, which will not automatically restore when needed.
Powering off and on each day would also drastically increase the chances of a disk drive failing.
The satellite boxes need to be powered all the time for recording and automatic updates of both software and programme guides (around 3 to 5 am).
The printers can be turned off, but they take ages to boot up and it's a real pain when you print to one, it fails and you have to go downstairs
to turn it on, wait for it to boot, clean and establish a network connection, go back and re-print, then come back to collect the print out.
Two streaming music players can be turned off fully, but on powering up, it can take up to 15 minutes for them to re-establish their network links,
find the server and re-check the libraries.
[Edited on 19/2/24 by SteveWalker]
Mr Whippy
posted on 20/2/24 at 07:25 AM |
I wonder what your combined wattage is for all that is?? add in the TV's, heating, fridge, freezer. It's funny how it all gradually mounts
up. You could perhaps try adding some mechanical timer switches to turn off things that take a while to boot up, so that they come on shortly before
you come back from work? just an idea... I have the wifi hub on one of those so it turns it off when the kids are meant to be getting ready for bed,
saves me having to go upstairs to switch it off and on each night
ReMan
posted on 20/2/24 at 12:05 PM |
This was my "obsession, when we first got a smart meter a couple of years ago and in fact to my mind the only useful function, is knowing what
running when nothing significant is. After all if you boil the kettle, its 2.2 kw and theres nothing you can do about it.
I made a point of tracking down every last items tjat was drawing anything and got it down to 4W istr.
Now I know the lowest it will normally be is appreox 116W and so if I go to bed, or leave the house on holiday, its a good check that nothing
significant has been left on
www.plusnine.co.uk
Mr Whippy
posted on 20/2/24 at 12:30 PM |
Watt it costs you a year...
peter030371
posted on 21/2/24 at 10:18 PM |
Why is what I said a red herring? You basically agreed with me. I didn't go into the details of why they fail when you switch them on because
that is irrelevant just that they do fail which is the point in this context. The analogy of brake pipes makes no sense. And I do understand
electronics, setting up and owning an electronic design and assembly company for 30+ years it is useful to understand them just a bit
Mr Whippy
posted on 22/2/24 at 07:58 AM |
I'd love to see the data from all the testing done to determine these findings.
Also if that has been discovered, why do manufacturers not design the electronics to help soften the "blow" from fully switching on a
device, so we don't have to leave them simmering on low heat 24/7?
posted on 23/2/24 at 08:25 AM |
It's not really in their interest to do that. It would cost more and reduce their future sales.
