Author: Subject: Alternator high output….
The Baron
posted on 13/4/24 at 04:17 PM Reply With Quote
Hi all,
I’m in the middle of performing a rewire on my Locost.
I have the wiring at a stage where the engine will start and run quite happily, so now moving on to the other systems.
I happened to check the alternator output whilst the engine was running, before I actually connected the alternator charging cable…… it was pushing out 28v which seems a lot……
Is this normal? (was expecting 13.8 to 14.8 ish)
Any ideas.
Cheers in advance
Baron
obfripper
posted on 13/4/24 at 04:37 PM Reply With Quote
Without the battery connected in the system, the regulator will not be able to control the output voltage.
There shouldn't be a fault once the battery is wired in, it's also the reason you should not run an engine without a battery (or disconnect the terminals while running), as the voltage getting to those levels can mess up a lot of ecu's.
Dave
The Baron
posted on 13/4/24 at 04:51 PM Reply With Quote
I’ll connect the wires up tomorrow, and give it a try,
Baron
gremlin1234
posted on 13/4/24 at 05:23 PM Reply With Quote
Dave
a friend of mine, long, long ago, had a motorbike that was doing very strange electrical things, it improved when we turned the headlight on, to give it some load.
The Baron
posted on 14/4/24 at 09:04 AM Reply With Quote
Quick question,
With regards the small positive cable from the alternator, is it best to connect this to permanent positive, or switched / ignition positive?
Baron
obfripper
posted on 14/4/24 at 06:18 PM Reply With Quote
Depending on the alternator you have fitted.
The main thick cable from +b directly to the battery, or to the main starter wire if it is more convenient (commonly used on many modern engines).
If it has a single auxillary wire (usually marked +d), then it should go through the indicator bulb (or load resistor/led combination) to the switched live.
If it has 2 or 3 wires, then it will have one wired as above, and then either/other directly to switched live (marked ig), and/or one directly to the battery (marked s).
Any other marked terminals can be ignored as they are usually test points used when the alternator is built.
Dave
The Baron
posted on 18/4/24 at 05:23 PM Reply With Quote
Ok… I’ve connected the alternator in.
I connected the thin brown wire to the switched live.
With the engine running, I’m getting 14.8 volts across the battery terminals, which I think is correct?
With the engine off, and the battery cables disconnected from the battery, I checked the continuity across the leads, and was surprised to see there was still continuity. So set the meter to resistance and got 1400ohms…. Is this normal?
Thanks in advance, I’m a little out of my comfort zone,
Baron
obfripper
posted on 18/4/24 at 07:21 PM Reply With Quote
That is the correct regulated voltage for a modern lead-calcium battery, alternators designed for the older lead-antimony battery technology used a 14.4v voltage regulator as a slightly lower voltage is required to achieve a full charge.
Which lead are you measuring back to earth? If it is the main battery cable, a resistance of 1400ohm would indicate a quiescent current of around 9mA, which is a reasonably low amount, as it will be a normal combination of the regulator being in circuit and possibly slight current leakage of the rectification diodes.
If it is the thin cable, it is connected to a switched live and so will not affect the battery without the engine running. It will draw current in use to feed the slip rings on the alternator armature, this current is what controls the output voltage of the alternator and is a normal function of the regulator.
For a 40Ah battery, this would give roughly 100 days+ standby and a battery will self discharge by nearly half in that time without being connected anyway.
It's not enough to be worried about, and you may also find the way the meter operates may make the resistance appear lower than it actually is, an accurate amp clamp or in circuit dmm ammeter would confirm the actual quiescent current but would not be necessary.
On a modern car, I would be looking for the total quiescent current with everything shutdown to be in the 20-40mA range,and issues are not normally noticeable until it is above 60-100mA depending on the battery size.
Which terminal type(s) did your alternator have?
Dave
The Baron
posted on 20/4/24 at 04:27 PM Reply With Quote
Hi, I was literally measuring between the battery leads.
I can’t see the socket (without taking the alternator off, which means I need to take some other bits off as well (might re-jig some bits around to tidy stuff up)
But!!!! I can see it’s got Nissan stamped on the housing (can’t see a part number though, might be out of sight)
I did get a memory flash back from over 15 years ago….. the alternator (and the radiator) both came off a Nissan micro (I even remember it being red!)
A google suggests the plug might be marked with a ‘L’ & ‘S’. I took the gamble and connected the plain thin brown wire to the switched live & hey presto (I guess it’s the ‘S’ connection)…. It worked and with every thing connected the voltage across the battery is 14.8v (as below)
Thanks for pointing me in the right direction, hopefully rest of the re-wire should be finished this weekend…..
Now that I have cut the rest of the old loom out, I can see the universal loom I originally used all those years ago is universally rubbish.
The one I am making from scratch is much neater and more logical.
Just got the final bit of joy to go with the sierra stalks, but there seems to be lots of diagrams available for them.
Thanks again.
Baron
