Oliver Jetson
posted on 27/2/05 at 05:18 PM |
205 tyres on 6" rim?
Will 205 wide tyres fit on a 6 inch rim?
(I want to know whether I can put some 205 Yoko 32/48's on my 13inch ford RS 4 spokes)
Oli
zilspeed
posted on 27/2/05 at 05:25 PM |
There is a school of thought that suggests that the rim would not be sufficiently wide to properly control the movement of the tyre laterally.
The same theory has it that something like a 195 section tyre on a 7" rim would be quite stretched - again laterally and would be more under
control.
I'll stop talking b0**ocks now and cut to the chase.
I would not think that 205s on 6" rims is a great idea. Not for ultimate grip and behaviour
Oliver Jetson
posted on 27/2/05 at 05:35 PM |
OK cheers, I guess I'll get 185's for now then.
Do you know what offset ford RS wheels are? Seen some 7 inch wheels for sale with a 100mm PCD - would they fit my locost?
scoobyis2cool
posted on 27/2/05 at 06:04 PM |
I think I read somewhere that the rim width should be approx 85% of the tyre width - so for a 205 tyre that gives a rim width of 6.86", so
roughly 7".
Pete
phelpsa
posted on 27/2/05 at 06:54 PM |
No.
Adam
zetec
posted on 27/2/05 at 07:02 PM |
You will find most makers spec the limits you should use for a given tyre. It seems to be the higher the aspect ratio the more suited the tyres are to
narrow rims. I was looking for a while for 205/55 to fit on my 6" rims and have just seen Toyo 888s are OK.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
richardR1
posted on 27/2/05 at 07:12 PM |
For 205/60x13 tyres the permissible rim width is 5.5 to 7.5" The preferred recommended size is 6 or 6.5" so your rims are perfect for
these. This data is from my Yokohama tyre technical guide. HTH
mookaloid
posted on 27/2/05 at 07:20 PM |
No.
Adam
Great post Adam.......
posted on 27/2/05 at 07:25 PM |
its a blinder! ford is 108 pcd, innit? so how can they be ford rs wheels with a 100 pcd? unless they're just 'in the style of'.
ignore me im rambling again...
posted on 27/2/05 at 07:49 PM |
A tyre from the narrow end of a rims fittment band generally gives best handling, this usually isn't the same as the greatest lateral grip &
traction.
205 is a permisable fittment for a 6" width rim only slightly on the wide side.
Oliver Jetson
posted on 27/2/05 at 07:57 PM |
Joel, the ones I've seen for sale are in the style of rs wheels, so with fords bein 108pcd i guess they ain't for a ford!
Think I mite go for 205's on the back and 185's on the front - what you think?
Oli
Gazza
posted on 27/2/05 at 08:28 PM |
Superlights
I've gone for 6x13 Superlights with a 205/60/13 rear and 185/60/13 front - looks the mutts with a chubby fat rear end.....
Just a bag o' rusty spanners
phelpsa
posted on 27/2/05 at 08:31 PM |
quote: Originally posted by mookaloid
No.
Adam
Thanks mook
scoobyis2cool
posted on 27/2/05 at 08:54 PM |
Hi Gazza, have you got any pics of those wheels? At the moment I've got 15" wheels but I really love the look of smaller superlights so am
thinking of changing them at some point.
Pete
phelpsa
posted on 27/2/05 at 09:15 PM |
Do you have a disc braked rear end? If so you will need split rims.
Adam
Gazza
posted on 27/2/05 at 09:23 PM |
superlights
I'll Take few pics.........
posted on 27/2/05 at 09:42 PM |
i found out the other day that 13s dont fit over ABS front hubs, due to the bigger caliper.
Gazza, i like your thinking, thats almost exactly what im aiming for. Just looking around for suitable minilights (or reps) for the arse end. ive got
some 5.5 ones for the front, im thinking 6 or 7 for the rear, and some cut slicks lots of fun... when i buy new back running gear... sold it all
just now
phelpsa
posted on 27/2/05 at 10:51 PM |
go for 7" rears, with 205/60s
