Author: Subject: zetec sump
RICK1
posted on 2/3/05 at 08:00 PM Reply With Quote
zetec sump
fitting 2litre zetec engine to velocity does sump+pick up pipe after 2 be changed 2 a escort zetec sump. also thanks luego quick and no hassle this time keep good work up?
shaywez
posted on 2/3/05 at 08:12 PM Reply With Quote
If changing to an escort sump you also need to change to the Escort pick-up pipe as it is shorter, as is the sump
RICK1
posted on 2/3/05 at 08:34 PM Reply With Quote
will escort sump give me enough ground clearence i no about pick up pipe?
shaywez
posted on 3/3/05 at 07:09 AM Reply With Quote
Escort sump will give you plenty of ground clearence, i would still be wary of large speed bumps though. The escort sump will give you 21mm more clearence than the mondeo one
bob
posted on 3/3/05 at 07:52 AM Reply With Quote
I'm going to chop the bottom off my mondeo zetec sump,basically copying the dunnel sump and shortening the pick-up.
Its speed hump hell on most of my routes to work so i cant really cope with the 21mm less from the escort sump,just a case of finding someone who can TIG weld
bob
posted on 3/3/05 at 07:53 AM Reply With Quote
mondeo sump in basic form,i'll make the bottom level. Rescued attachment MK Indy build pics 001.jpg
bob
posted on 3/3/05 at 07:54 AM Reply With Quote
should end up like this.
[Edited on 3/3/05 by bob] Rescued attachment 04740003.jpg.small.jpg
