Author: Subject: Rover v8 Viscous coupling removal
Paul (Notts)
posted on 5/3/05 at 04:20 PM Reply With Quote
Just started stripping down a 1988 3.5 efi rover V8 engine, which I intend to rebuild.
I may be thick but I am puzzeled by How to remove the fan and Viscous coupling from the water pump.It appears to have a wound spring on the fromt of the viscous coupling and four bolts on the back which presumably hold the fan to the coupling.
How do I remove them from the pump????
Paul
posted on 5/3/05 at 04:47 PM Reply With Quote
Not sure but is there a large hexagon betwwen the 4 bolts and the viscous coupling? if so it has a left hand thread . If you don't intend using it again just put a bluntish chisel close to edge of hexagon and give it a sharp tap so that it rotates anticlockwise, this usually undoes viscous couplings .H.T.H. Rusty
mark_UK
posted on 5/3/05 at 05:24 PM Reply With Quote
If its the same set up as Fords theres a thin nut behind the viscous unit which needs a very thin,cranked spanner to undo, on fords its either 32 or 34mm cant remember which.Any car spares shop selling Laser brand tools should have one.
[Edited on 5/3/05 by mark_UK]
white130d
posted on 5/3/05 at 09:31 PM Reply With Quote
Yep
Unscrew the big nut behind the fan..and it is backwards threaded....
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
Paul (Notts)
posted on 5/3/05 at 09:38 PM Reply With Quote
How do i stop the pump turning wnen i do this
thanks
paul
Simon
posted on 6/3/05 at 12:28 AM Reply With Quote
Leave the fan belt on?
Simon
clbarclay
posted on 6/3/05 at 08:10 AM Reply With Quote
And if it then carries on turning push in on the fan belt to tighten the belts grip.
NS Dev
posted on 6/3/05 at 09:18 AM Reply With Quote
Or just follow Rusty's advice above, this has worked every time I have done this on Fords and RWD Opels, usually frees with one sharp tap, even with no belt on at all.
[Edited on 6/3/05 by NS Dev]
wilkingj
posted on 6/3/05 at 10:11 AM Reply With Quote
I have just done this , and OFF the engine as well!..
You need the double ended Laser (make) cranked fan spanner, Its a LEFT HAND thread (Think first before undoing).
I have some bits of old seatbelt, I twisted it into like a rope, wound it round the pulley belt, then I twisted the two end round and round until it tightened on the pulley, then I put the twisted tail of the belts in the vice, tightened and twisted it up as tight as I could get it.
Then put the spanner on and clouted it with a heavy hammer.
This is easier if you are a freak or a Indian goddess, 'cos three or more hands are a definate advantage here.
Comes undone failry easily, but needs a good clout with the hammer. IN THE RIGHT DIRECTION
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 6/3/05 at 05:21 PM Reply With Quote
Why buy a spanner you are likely to use once? bet you already have a bluntish chisel , I would expect to have undone a viscous coupling using this method before you have even found an old fan belt, seat belt or any other means of holding the pulley. One sharp tap is all it takes normally
posted on 6/3/05 at 05:55 PM Reply With Quote
I belted mine with the chisel and broke the water pump end off. It's easy then, you just put the rotor in the vice, undo it and then buy a new water pump. I don't know what rover v8 ones cost but pinto ones are about £10.
clbarclay
posted on 6/3/05 at 07:59 PM Reply With Quote
Should have used the chisel and bust the water pump whalst I was changing the viscos unit on family range rover, the water pump died only 100 miles later.
Diddn't need a special spanner for removing it, just an ordinary one. But then I do have a large selection of big spanners.
