Author: Subject: Bonnet rubber
dr-fastlane
posted on 22/3/05 at 05:49 PM Reply With Quote
Bonnet rubber
Which type of rubber have you put between an aluminium bonnet and the scuttle + nosecone?
Has someone perhaps pictures?
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
posted on 22/3/05 at 06:48 PM Reply With Quote
Better than my Dutch, I've used a U shaped rubber trim about 19mm wide,sorry have no pictures. Think I got it from Woolies at a show somewhere
NS Dev
posted on 23/3/05 at 01:27 PM Reply With Quote
Try here, as above, have anything you need............
http://www.woolies-trim.co.uk
DarrenW
posted on 23/3/05 at 02:29 PM Reply With Quote
dr-fastlane,
interesting avatar. Are you fitting full bonnet or just a half size one???
Im using u trim around bonnet edge but im also using foam tape around the scuttle, top of chassis and nose cone where the bonnets will sit.
clbarclay
posted on 23/3/05 at 06:45 PM Reply With Quote
How about a strip of thin rubber under binnet on top of scuttle/nose cone, old bicycle inner tubes could be ideal and 'low cost'. Just stick the tube to the under side of the bonnet with suitable glue.
Or cut strips from old car inner tubes etc.
[Edited on 23/3/05 by clbarclay]
irvined
posted on 24/3/05 at 11:59 AM Reply With Quote
Hello
I'm using foam tape, it compresses down nicely .
dr-fastlane
posted on 24/3/05 at 05:01 PM Reply With Quote
DarrenW: That photograph on my avatar is taken when I cut an Viento noscone in half and made it fit my +9 inch wide chassis. The bonnet is gone be an full size one.
I think that i gone use U- shaped trim like on the image below.
[Edited on 24/3/05 by dr-fastlane] Rescued attachment 4610025groot.gif
clbarclay
posted on 24/3/05 at 05:35 PM Reply With Quote
I presume the lower part of the diagram ilustares how tight a radious the trim can go round, if so what is the units cm or inch?
dr-fastlane
posted on 27/3/05 at 07:56 AM Reply With Quote
clbarclay: the upper drawing is in mm and bottom in cm
[Edited on 27/3/05 by dr-fastlane]
splitrivet
posted on 27/3/05 at 07:12 PM Reply With Quote
I used sticky back insulation tape about 4 mill thick,just the job.
Bob
dr-fastlane
posted on 5/4/05 at 04:48 PM Reply With Quote
last weekend I have received the U-shape trim for the bonnet and foam that i use for the nosecone + scuttle.
now I have to made an cover for the EFI
darren(SA)
posted on 5/4/05 at 07:14 PM Reply With Quote
I bought some extruded rubber called 'fender weld' which is used for beetle fenders, looks good, and its cheap over here.
