W A M
| posted on 28/3/05 at 10:29 PM |
Hayabusa sump & loom mods help required
Got a 99 busa & need to mod sump, ie chop & baffle. Also need help with modding the loom to run in a westie if possible. Has anyone got a
picture of sump or loom diagram ?
OX
| posted on 28/3/05 at 11:23 PM |
i have a westy sump you can buy for the busa
W A M
| posted on 28/3/05 at 11:38 PM |
IS this the wet sump & how much?£££
OX
| posted on 29/3/05 at 09:30 AM |
yes it is a wet sump but you wont be needing it now seeing as your gonna modify yours
alister667
| posted on 29/3/05 at 06:02 PM |
Have mercy Ox, the man has a trackday at Kirkistown on Sunday he's trying to get to!!!!
Post him a pic at least!!
WAM - I take it it's you I was talking to at the NI7s do on Sunday, and at the petrol station afterwards?
http://members.lycos.co.uk/alister667/
bike_power
| posted on 29/3/05 at 10:02 PM |
Got this list of loom mods from Walt on the Yahoo BEC list, worked for me but mine is a Dax Rush and I made the rest of the loom myself, if
you're using a Westfield loom you'll need to check with Westfield.
> Tilt takes a 68Kohm resistor, 1/2 W but use 1 W because it will take more
> physical abuse.
> Sidestand takes a jumper
> Clutch lever position takes a jumper
> ECU needs a 150ohm resistor between O/Y and B/W 1/2W but use 1W because it
> will take more physical abuse
> Engine stop switch takes a jumper
