Author: Subject: Which fuel sender
Matthew_1
posted on 8/4/05 at 01:59 PM Reply With Quote
Which fuel sender
Been searching on here for details of fuel senders and there dosn't seem to be any definitive answer to the question ...
Which fuel sender is best to top mount in a locost sized (and shaped) fuel tank of about 7 gallons ?
posted on 8/4/05 at 02:01 PM Reply With Quote
IWI any from a car can be adapted prett easily cant it?
locoboy
posted on 8/4/05 at 02:02 PM Reply With Quote
senders are more often than not matched to the guage, so what type of guage do you have?
Locoboy
tri
posted on 8/4/05 at 05:09 PM Reply With Quote
the sender we used was to match the gauge
Tri
irvined
posted on 8/4/05 at 06:46 PM Reply With Quote
I've got a smiths telemetrix guage, and bought a luego 6 holed smiths sender.
THe problem with this was that although it fits the flange on my gts tank, it was designed to go in sideways, i had to bend the float around 180 degrees and shorten it, but it works great.
I tihnk most senders will require a little bashing to get them to work as needed.
HTH
tks
posted on 11/4/05 at 01:14 PM Reply With Quote
i used one from a BMW 635i
wy? i saw it and loved the idea:
- Pickup point
- Return point
- Level meter
- Inlet Filter
all in one thing...
soow make one hole and you are there..
TKS
