Author: Subject: Where can i buy this??
tks
posted on 9/4/05 at 12:05 AM Reply With Quote
I'm from spain sow don't have much resources wich UK company sell these..??
stevebubs
posted on 9/4/05 at 12:34 AM Reply With Quote
If you're on about converters, then Think Auto is probably a good place to start, or www.rswww.com
whpracer
posted on 9/4/05 at 10:44 AM Reply With Quote
a lot of company's sell them incl.
GTS,
take a look at
http://www.rallydesign.co.uk/catalog/default.php
saigonij
posted on 9/4/05 at 07:53 PM Reply With Quote
which bits are you after? the actual screw in connector with the pipe sticking out vertical to allow you to connect a remote resevoir?
if so, ill get some made for you and send them out to you. they are only M12 connectors with a bit of pipe on the end.
