Author: Subject: Mid-engined Stuart Taylor
Humbug
posted on 20/4/05 at 07:43 PM Reply With Quote
I was just in the garage taking some pictures of the engine in the bay and I realised that I have a mid-engined car!
It's a Stuart Taylor, and the whole of the engine is clearly behind the front axle... therefore it's a middy?
phelpsa
posted on 20/4/05 at 07:50 PM Reply With Quote
Yep, this makes most front engined BECs very well balanced!
Adam
[Edited on 20-4-05 by phelpsa]
Alan B
posted on 20/4/05 at 07:51 PM Reply With Quote
Er....no.
Mid-engined is between the axles, but BEHIND the driver.
Some people call the seven configuration "front-mid", but that's b o l l o c k s IMO....front is front is front.....
Of course that doesn't mean to say you don't have good weight distrubition, handling etc.
[Edited on 20/4/05 by Alan B]
spunky
posted on 20/4/05 at 08:02 PM Reply With Quote
there is a Stuart Taylor middy.
Mine...
The reckless man may not live as long......
But the cautious man does not live at all.....
Alan B
posted on 20/4/05 at 08:32 PM Reply With Quote
Yes indeed.....engine behind the driver, but ahead of the rear axle = mid-engined.
Purely an engine position relative to the driver designation.
Rorty
posted on 21/4/05 at 04:16 AM Reply With Quote
What about Dennis Palatov's cocktail? Is it not mid-engined?
Cheers, Rorty.
stressy
posted on 21/4/05 at 06:53 AM Reply With Quote
top job humbug
I see shes in then.
How far is the bellhousing/engine joint from the footwell bulkhead?
WHO DARES SPINS
Alez
posted on 21/4/05 at 01:51 PM Reply With Quote
While on this topic, do you know where the centre of gravity of the engine is located in a typical car? I think it's a bit in front of the front axle for most cars? How about car engined Sevens? And BMWs? (Which have the front axle at their very front.)
Alex
kb58
posted on 21/4/05 at 02:18 PM Reply With Quote
Ask the question again in a different way, I'm not sure I understand.
The CG of the *engine* is usually approximated by just looking at it.
OTOH if you're asking how to find the CG of the entire car, you can do it with a spreadsheet during design, which is a really good idea. Or, you can do it afterwards with scales.
If you're asking where the CG "typically" is, you can guess just by looking at it, but in the case of a Seven, it'll be just slightly forward of half-way between the axles.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
ned
posted on 21/4/05 at 02:22 PM Reply With Quote
unless you have a light engine and a full cage fitted, then it can be slightly towards the rear
Ned.
beware, I've got yellow skin
Alez
posted on 25/4/05 at 06:50 AM Reply With Quote
Hi, I really meant what I asked, I guess you can tell the CG of an engine by looking at it, my question is about the location of the engine in a typical front engine car with respect to the front axle. I think they are normally located a bit in front of the axle, but I'm not sure. They are quite behind in Sevens. I'm sure that changes handling and weight distribution quite a lot. I was thinking about the "bad" reputation front engined cars have dynamics-wise and how Sevens and others are very different on that respect.
Alex
