FUORISERIE
posted on 6/5/05 at 10:58 AM |
Concept Seven design
Hi all, it's my first post here
I've been working on seven replica new body design, and wanted to have your feedback on the two proposals I have on my website.
The website is undergoing a few changes , but you can see them at:
www.fuoriseriedesign.com
click on transportation design and then product design.
Thanks for your feedback and comments
Italo
omega 24 v6
posted on 6/5/05 at 11:19 AM |
I lke the seven very clean lines and futuristic.
NS Dev
posted on 6/5/05 at 11:51 AM |
Ariel Atom???
andyps
posted on 6/5/05 at 12:17 PM |
Some good looking designs on there, what are your thoughts on getting them into production?
[Edited on 6/5/05 by andyps]
Mave
posted on 6/5/05 at 02:11 PM |
I like the rear of the gullwing seven. The lip under the nose opening is a bit too long.
And I like the fact that you use curved windows, instead of the flat screen that every Seven still uses (when is the Seven stepping into the 21st
century?!?!)
Haven't I seen the green one already in connection to a new Seven to be launched by MK Engineering?!?
Dale
posted on 6/5/05 at 09:30 PM |
Some of the nicest redesigns I have seen. The gull wing is cool but I would it would require some fancy design to hing the curved dorpanals as shown
-maybe not. Only changes I would make - which i have seen in pretty much any design of newer sevens with doors is the cars have to be wider to allow
comfotable posistioning of the outside arm . I was in a new fort gt last week -2005 ford gt40ish) The doors are hollowed out at the elbow and
forearm to give some room. Sadly enough I barely fit in the car and would be put off of buying one (even if I could afford one) as I did not fit as
my head was against the roof.
Still excelent work
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
posted on 6/5/05 at 09:38 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=18003
same piccy there?
FUORISERIE
posted on 9/5/05 at 09:34 AM |
I posted this rendering in late 2004 on
www.pistonheads.com
to get some feedback on the design direction I was taking, and I guess it must have sperked the interst from MK Engineeringit????!!!!!!!!!!!!.. well
if they are interested It would be nice to hear from them or any other, I wouldn't mind giving them my design!!!!!!.
Maybe I should just start looking for a running locost chassis and build the prototype myself..
Thanks for your feedback, keep it comming it helps a lot in the design process odf this project.
Italo
FUORISERIE
posted on 11/5/05 at 02:24 PM |
You could also check my website if you like
cheers
Italo
Ferg
posted on 12/5/05 at 04:20 PM |
Great designs there Mr.Newcomer. Welcome to Locostbuilders.
Have you designed a 3 wheeler yet!!!
Cheers, Ferg
flak monkey
posted on 12/5/05 at 04:25 PM |
The pic above looks remarkably similar to the Lotus 340R that they released a few years ago....dont you think?
Sera
http://www.motosera.com
FUORISERIE
posted on 13/5/05 at 12:47 PM |
Hi Ferg
Working on it!!! I will be showing something regarding the threewheeler, you will be surprised............
Thanks for the feedback on the design, and I did take inspiration fron the Ariel Atom and the 340 r, they are the closest car to what a new seven
should be in the 21st century.
I have a more extreme seven that is not for public view yet, but could be the basis for a new project
Italo
fuoriserie1
posted on 24/12/10 at 12:59 PM |
Cheers, Ferg
It took some time, but here you go......
http://www.tercyclo.blogspot.com/
