Author: Subject: Is it ok to upshift without the clutch?
darth G-F
posted on 7/5/05 at 01:41 AM Reply With Quote
I have a Busa powered Caterham, I was wondering how safe it was for the transmission to do that on a regular basis?
It is way cool to upshift without the clutch, as long as I don't break anything.
let me know.
Hayabusa powered caterham
spunky
posted on 7/5/05 at 07:26 AM Reply With Quote
No problems with clutchless upshifts,
Bike gearboxes are very tolerant of this and it helps reduce the backlash in a BEC.
Use the clutch between 1st an 2nd 'cos the neutral screws it up and keep the revs high....
John
The reckless man may not live as long......
But the cautious man does not live at all.....
posted on 7/5/05 at 07:30 AM Reply With Quote
It is quite common not to use clutch for upshifts on a BEC. Some people don't even bother for downshifting although most probably do use clutch for downshifting. It can be a bit clunky sometimes going from 1st to 2nd without the clutch, especially if you're taking it steady (its fine if you're hammering it though). Just back of the throttle ever so slightly before shifting.
darth G-F
posted on 7/5/05 at 01:09 PM Reply With Quote
I knew I could do it, I was just afraid of long term wear to the transmission.
Thanks.
Coose
posted on 9/5/05 at 10:46 AM Reply With Quote
I wouldn't do it on downchanges - you run the risk of smashing dogs.....
I rarely use the clutch on upchanges, especially when on two wheels.... You'll find it to be somewhat smoother than using the clutch when nailing it!
Spin 'er off Well...
