Author: Subject: CBR1000 Installation to Locost Chassis.?.?
jamestziros
posted on 16/5/05 at 08:06 AM Reply With Quote
Hi
I have a CBR1000 I intend to put in to a Locost chassis. Does anyone have any images, and suggestions for mounting.
Any thing I should look out for?
Thank you in advance.
James
jamestziros@btopenworld.com
jambojeef
posted on 16/5/05 at 09:45 AM Reply With Quote
Hi there,
Its an easy fit - the only thing to catch you out is the oil filter which on mine almost sits right on top of the chassis rail.
I know that the cradles are quite popular using the top mounts in the bike - this is how I've done mine though with solid lower mounts - nylon side mounts and an ali brace.
Hope that helps,
jamestziros
posted on 16/5/05 at 10:06 AM Reply With Quote
Geoff
Thanks for that, I assume your sump sits below the chassis?
any other pics greatly appreciated - looks good.
Yes I noticed the Oil filter....! mybe I'll move it.
James
jambojeef
posted on 16/5/05 at 11:36 AM Reply With Quote
Yep,
Sump Sits below the chassis by about 2" should be ok without chopping I think and bonnet line should clear the rocker cover without a bulge - if all goes to plan!
Havent got any better piccies at the minute - will take some tonight.
Geoff
bigbriglasgow
posted on 16/5/05 at 06:46 PM Reply With Quote
Speak to kissy he has done it and its on the road
cheers
Brian
coz its a bit of an animal
Shandylegs
posted on 17/5/05 at 09:49 PM Reply With Quote
Just uploaded a few pictures to the archive, although not the best quality they may be of some use.
Ta
Shandylegs
jambojeef
posted on 17/5/05 at 11:47 PM Reply With Quote
thats a sweet looking install
whpracer
posted on 18/5/05 at 08:40 PM Reply With Quote
Hi Mate,
I'm also busy with getting the honda engine in the chassis. I should be a very reliable engine with a little bid more power than a blade. Maybe in a later stadium a turbo
some pic's
or
http://members.lycos.nl/kitcar/
jamestziros
posted on 21/5/05 at 09:59 PM Reply With Quote
Thank you all
Thank you all for your help - I'll be adding some of my own when i get a reasonable amount done...!
Berracvh
posted on 22/5/05 at 07:18 AM Reply With Quote
Hi
Im converting from cvh 1.6 with 4speed to cbr1000F -91.
The cvh +4sp are out of the locost.
Will get the cbr on tuesday.
Anything special to think about ?
I think some of you have converted from cvh to bike engine.
Going the electric reverse route.
The shifter , Is it possible to use a cable (clutch) ?
/Johan
